Tooltip is slow
Posted: Mon Jun 27, 2016 1:43 pm
I have added the below CSS class and html code to achieve the chart responsive and working fine. But sometime tooltip is not showing or sometime it took more time to show tool tip. You can reproduce the same issue using sample code. Is there any way to fix the tooltip related issue? or How can we improve the tooltip speed?
One more thing what I observed is that this problem occurs when we assign height and width 100% to canvas using style sheet ( "<canvas id="canv" style="width:100%;height:100%;display:block;padding-left: 0;padding-right: 0; margin-left: 0; margin-right: 0;">")
If I don't set width and height to canvas the chart is displaying out of div(box), so how can we fix tooltip issue in this scenario?
<!DOCTYPE html>
<html>
<head>
<title>TeeChart JavaScript Custom Axis Labels Example</title>
<!--[if lt IE 9]>
<script src="../../src/excanvas/excanvas_text.js"></script>
<script src="../../src/excanvas/canvas.text.js"></script>
<![endif]-->
<style type="text/css">
.col-md-12 {
width: 100%;
#canvas {
width: 90%;
height: 100%;
/*background-color: pink;*/
z-index: 100;
</style>
<script src="../../src/teechart.js" type="text/javascript"></script>
var Chart1;
function draw() {
Chart1 = new Tee.Chart("canvas");
var pointXY = new Tee.PointXY([355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200,
191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145,
153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273,
276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108,
104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270,
279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275,
269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238,
229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128,
137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276,
279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101,
97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304,
311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163,
154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228,
239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278,
275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220,
210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163,
172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320,
314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262,
256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115,
122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268,
267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95,
96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328,
331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266,
270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108,
104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296,
304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154,
143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239,
250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275,
269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210,
200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172,
183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314,
305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256,
252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122,
128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350,
346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267,
268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96,
98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331,
333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270,
271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104,
101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304,
311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258,
259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143,
135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250,
259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269,
264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200,
191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183,
194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305,
299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252,
244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128,
137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289]);
pointXY.format.stroke.size = 4;
pointXY.pointer.style = "ellipse";
pointXY.pointer.width = 5;
pointXY.pointer.height = 5;
Chart1.addSeries(pointXY);
Chart1.axes.left.setMinMax(80, 360);
Chart1.axes.left.format.stroke.fill = "green";
Chart1.axes.left.title.text = "Left Axis";
Chart1.axes.bottom.title.text = "Bottom Axis";
Chart1.title.text = "Mouse-over Tooltips";
Chart1.title.format.font.style = "18px Verdana";
Chart1.series.items[0].format.stroke.fill = "darkorange";
Chart1.series.items[0].pointer.visible = true;
Chart1.panel.format.stroke.fill = "";
Chart1.panel.format.shadow.visible = true;
tip = new Tee.ToolTip(Chart1);
tip.render = "dom";
tip.domStyle = "padding-left:8px; padding-right:8px; padding-top:0px; padding-bottom:4px; margin-left:5px; margin-top:0px;";
tip.domStyle = tip.domStyle + "background-color:#FCFCFC; border-radius:4px 4px; color:#FFF; ";
tip.domStyle = tip.domStyle + "border-style:solid;border-color:#A3A3AF;border-width:3; z-index:1000;";
Chart1.tools.add(tip);
tip.ongettext = function (tool, text) { return '<font face="verdana" color="blue" size="1">' + "Text:\n" + text + '</font>'; }
Chart1.legend.visible = false;
Chart1.draw();
function resize(chart) {
var canvas = chart.canvas;
var width = 80, height = 70;
var w = width * window.innerWidth / 100;
var h = height * window.innerHeight / 100;
canvas.width = w;
canvas.height = h;
chart.bounds.width = w;
chart.bounds.height = h;
chart.draw();
window.addEventListener('resize', function () {
if (Chart1 != undefined)
resize(Chart1);
}, false);
</script>
</head>
<body onload="draw()" >
<div class="class=" col-md-12">
<center>
<br><canvas id="canvas" width="1240" height="460">
</canvas>
</center>
</div>
</body>
</html>
