Financial indicators in Javascript / HTML5
Posted: Thu Jan 07, 2016 8:55 am
by 15676988
Does teechart support financial indicators in Javascript / HTML5? I couldn't find any about this. If it's possible where I can find example to integrate it?
Re: Financial indicators in Javascript / HTML5
Posted: Thu Jan 07, 2016 11:25 am
I'm afraid TeeChart Javascript/HTML5 doesn't include functions like the other versions.
However, you can always do the calculations from your main series and add the according points to an extra series manually.
Don't hesitate to let us know if you find any problem with that.
Posted: Fri Jan 08, 2016 1:36 pm
by 15676988
Thanks for your answer. May you apply an example how to integrate some of these Trend line, Bollinger, MACD?
Posted: Mon Jan 11, 2016 12:00 pm
A simple example would be this kind of mean function:
var Chart1;
function draw() {
Chart1=new Tee.Chart("canvas1");
candle1 = new Tee.Candle();
Chart1.addSeries(candle1);
candle1.addRandom(20);
msecsInADay=86400000; //24*60*60*1000
candle1.data.x=new Array(candle1.count());
var now=new Date(), tmp;
for (t=0; t<candle1.count(); t++) {
tmp=new Date(now.getTime() + t * msecsInADay);
candle1.data.x[t] = tmp;
Chart1.legend.visible = false;
myLineFunc1 = new MyLineFunc();
Chart1.addSeries(myLineFunc1);
myLineFunc1.data.source = candle1;
myLineFunc1.fillFromDataSource();
Chart1.draw();
MyLineFunc=function(o,o2) {
Tee.Line.call(this,o,o2);
this.fillFromDataSource=function() {
if (this.data.source instanceof Tee.Series) {
s = this.data.source;
sum = s.data.close.reduce((a, b) => a + b, 0); //sum of close values in the candle
mean = sum / s.count();
this.data.values = [mean, mean];
this.data.x = [s.data.x[0], s.data.x[s.count()-1]];
MyLineFunc.prototype=new Tee.Line();
Posted: Thu Jan 14, 2016 9:53 am
by 15676988
It will help us thanks a lot!
Posted: Tue Mar 01, 2016 4:08 pm
by 15676988
Hi again,
we need from your help about the Bollinger Bands indicator
The bands are calculating from all data as is below:
- BBAllData.png (83.86 KiB) Viewed 25769 times
but the lines are very curved now. We want to make lines more smooth and straight.
When try to use only one fifth part of all data we lost the lines as is below:
- BB1.5Data.png (65.08 KiB) Viewed 25776 times
Please advice how can achieve it.
Posted: Wed Mar 02, 2016 9:04 am
It's difficult to guess what are you exactly doing. Could you please arrange a simple example we can run as-is to reproduce the situation here? (note our
Bug Fixing Policy).
Posted: Fri Mar 11, 2016 1:24 pm
by 15676988
When were start to prepare a simple example in the meantime we found the mistake.
Sorry for the unnecessary post.
Posted: Fri Mar 11, 2016 2:53 pm
I'm glad to hear it!
