Null Value & Axes Title Angle and Show Time In Multiple Axes
Posted: Wed Jan 09, 2013 4:37 pm
by 17662183
Hi,I'm using TeeChart Javascript/HTML5
code:
Chart1.axes.items[0] = Chart1.axes.left;
Chart1.axes.items[4] = Chart1.axes.add(false,false);
1.When first loading,it will show Only Chart1.axes.items[0].Title.Text
Until MouseMove,it show Chart1.axes.items[4].Title.Text ,Chart1.axes.items[5].Title.Text...etc
Can any solution show all Axes Title in first loading at on time?
2.In Y Axes,Axes.Title comes always in Vertical,I want it be on Horizontal
And any method set Axes.Title.Angle or turn it to Horizontal?
3.Series in null/NaN Value ,How to set it in break line?
Thanks in any help!
Re: Null Value & Axes Title Angle and Show Time In Multiple Axes
Posted: Mon Jan 14, 2013 3:05 am
by 17662183
Hi, I've ready your reply in Stackoverflow
ans1-will fixed it for the next maintenance release
ans2-Chart1.axes.left.title.rotation = 90;
but question3 still not resolve
Eg:
var s0=Chart1.addSeries(new Tee.Bar([5,2,null,6,7,null,4,6,5]));
s0.title="Sugar";
s0.data.labels=['A','B','C','D','E','F','G','H',I'];
Although point C & point F is disable
but willl have line start in point B to point D & point E to point G
Any solution to set a
break line in point B to point D & point E to point G
Thanks in any help!
Posted: Mon Jan 14, 2013 3:34 pm
Hi Eden,
Eden wrote:your reply in Stackoverflow
Let me post it here the complete answer I wrote
there.
Eden wrote:1.When first loading,it will show Only Chart1.axes.items[0].Title.Text
We've fixed it for the next maintenance release. Thanks for reporting it.
Eden wrote:2.In Y Axes,Axes.Title comes always in Vertical,I want it be on Horizontal
We've implemented a new rotation property for the all the axes titles.
This will also be available with the next maintenance release and will work with 0, 90 and 270 degrees by now.
Eden wrote:3.Series in null/NaN Value ,How to set it in break line?
Eden wrote:Eg:
s0.title="Sugar";
Thanks in any help!
Regarding this 3rd question, you would like to have a break in your axis like the AxisBreaks Tool, or you just don't want the C and F Axis labels to be drawn, showing a blank space where the respective values would be if visible?
Posted: Tue Jan 15, 2013 7:49 am
by 17662183
Hi,Yeray
In 3rd question,Is any solution to set the line between point B and point D & the line between point F and point H are disable/invisible?
var Chart1;
function draw() {
Chart1 = new Tee.Chart("canvas1");
Chart1.axes.left.title.text = "Data";
var series = new Tee.Line(Chart1);
Chart1.addSeries(series);
series.data.values = [5, 2, null , 6, 7, 1,null , 6, 5];
series.data.labels = ['A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I'];
Chart1.draw();
- no break line
- qp1.png (37.7 KiB) Viewed 23628 times
How to set a break line in point B to point D & point F to point H like this
- break line in point B to point D & point F to point H
- qp2.png (31.65 KiB) Viewed 23620 times
Posted: Thu Jan 17, 2013 8:43 am
We've added a new treatNulls property to the Line series so with the next maintenance release you'll be able to do this:
Chart1.series.items[0].treatNulls = "skip"; // default is: "dontPaint"
Posted: Mon Mar 25, 2013 12:40 am
by 17662183
Hi,your product is awesome!
When does it maintenance release?
Best Requard!
Posted: Tue Mar 26, 2013 11:42 am
Hi Eden,
I'm afraid I can't tell you a date for the next release to be published.
