I am using the following example from GitHub to load a chart on my server side blazor .net core 6.
https://github.com/Steema/TeeChart-NET- ... BlazorNET5
Unfortunately the chart disappear from canvas. If I press F5 to reload the page the chart appeared and disappear on a second.
Also I have another problem if you help me to resolve that issue. I need the Chart to load on button click and not on page load.
I would like to mention also that the blazor server render mode is server-pre-rendered because I am using rad zen controls and need that mode to work.
I will appreciate any help.
Chart disappear on Blazor Server Side
Re: Chart disappear on Blazor Server Side
Following my previous post, attached is a sample blazor server project on .net core 7 doing exactly what I had described.
- RenoptiTrader.UI.zip
- (10.03 KiB) Downloaded 1256 times
I see our demo works with NET 5 and reproduces the disappearing chart from NET 6.
We'll try to make a Blazor server demo in NET 6 or NET 7 as soon as possible.
At this point I'm not sure if it will require any modification in our library or just in the example.
