Draw Multiple Transparent Bands with DateTime Bottom Axis
jzarech
Post by jzarech » Wed May 18, 2016 3:02 pm
I'm trying to create transparent "highlight" bands on my chart to show important times.
Bottom axis is a datetime axis.
I have two issues --
#1) The Custom_Paint.htm example only draws one band and I need to draw multiple how would I draw multiples?
#2) How do I map a date onto the bottom axis to get the x1, x2 variables?
Thanks in advance for your help.
Joseph
Custom Pain Example:
<!DOCTYPE html>
<html>
<head>
<title>TeeChart JavaScript Custom Canvas Painting Example</title>
<!--[if lt IE 9]>
    <script src="../../src/excanvas/excanvas_text.js"></script>
    <script src="../../src/excanvas/canvas.text.js"></script>
<![endif]-->
<script src="../../src/teechart.js" type="text/javascript"></script>
var Chart1;
function draw() {
  Chart1=new Tee.Chart("canvas");
  Chart1.addSeries(new Tee.Line([50,30,20,70,10,60,40,50,10,0,100]) ).format.stroke.size=4;
  var myFormat = new Tee.Format(Chart1);
  myFormat.gradient.visible=true;
  myFormat.gradient.colors=["white","lime"];
  myFormat.transparency=0.3;
  Chart1.ondraw=function() {
    var x1 = Chart1.axes.bottom.calc(4), //what if this is a date value?
        y1 = Chart1.axes.left.calc(70),
        x2 = Chart1.axes.bottom.calc(7),// what if this is a date value?
        y2 = Chart1.axes.left.calc(40);
    // X,Y, Width, Height
    myFormat.rectangle(x1,y1, x2-x1, y2-y1);
  Chart1.draw();
</script>
</head>
<body onload="draw()">
<canvas id="canvas" width="600" height="400">
</canvas>
</body>
</html>
Re: Draw Multiple Transparent Bands with DateTime Bottom Axis
Post by Yeray » Thu May 19, 2016 9:34 am
First of all note the Custom Paint example in the demo draws a rectangle/shape. Here I modified it to draw an horizontal ColorBand:
http://www.teechart.net/support/viewtop ... 043#p71201
Taking that as a reference, I've modified the example to use datetime values for the bottom axis, and to draw two vertical ColorBands.
Note I've used slightly different approaches to draw them. The fist one uses a gradient and series values as x1 and x2; the second uses a single color and directly datetimes to calulcate x1 and x2:
        var Chart1;
        function draw() {
            Chart1 = new Tee.Chart("canvas1");
            Chart1.legend.visible = false;
            var line1 = Chart1.addSeries(new Tee.Line([50,30,20,70,10,60,40,50,10,0,100]) );
            line1.format.stroke.size=4;
            var oneDay = 86400000, oneHour = 60 * 60 * 1000, today = new Date().getTime();
            line1.data.x = [];
            for (var i=0; i<line1.count(); i++) {
                line1.data.x.push(new Date(today + i * oneDay));
            Chart1.axes.bottom.labels.dateFormat = "dd mmm";
            Chart1.axes.bottom.increment = oneDay;
            var myFormat1 = new Tee.Format(Chart1);
            myFormat1.gradient.visible=true;
            myFormat1.gradient.colors=["white","lime"];
            myFormat1.transparency=0.5;
            var myFormat2 = new Tee.Format(Chart1);
            //myFormat1.gradient.visible=true;
            myFormat2.fill="red";
            myFormat2.transparency=0.2;
            line1.beforeDraw=function() {
                var x1 = Chart1.axes.bottom.calc(line1.data.x[2]),
                    y1 = Chart1.chartRect.y,
                    x2 = Chart1.axes.bottom.calc(line1.data.x[4]),
                    y2 = Chart1.chartRect.y + Chart1.chartRect.height;
                myFormat1.rectangle(x1,y1, x2-x1, y2-y1);
                x1 = Chart1.axes.bottom.calc(today + 7 * oneDay + 5 * oneHour),
                x2 = Chart1.axes.bottom.calc(today + 8 * oneDay + 2 * oneHour),
                myFormat2.rectangle(x1,y1, x2-x1, y2-y1);
            Chart1.draw();
    </script>
jzarech
Post by jzarech » Thu May 19, 2016 4:45 pm
Wow! Perfect! Yeray thanks so much!!!
Post by Yeray » Fri May 20, 2016 8:57 am
jzarech wrote:Wow! Perfect! Yeray thanks so much!!!
You are welcome, Joseph! :)
Anders Balslev
Post by Anders Balslev » Wed Jun 17, 2020 7:44 am
Hi Steema
After searching quite some time, I found this post which fulfill my needs. :D
However - it's written i C-language.
Is it possible to translate the code solution into Delphi?
Br.
Anders Balslev
Post by Marc » Tue Jun 23, 2020 8:14 am
Thread moved to VCL forum. (I see that the issue has already been posted there too).
