I have problem with graphic with increment month, the date for each bar is not correct.
The increment seems fixed of 30 days.
If I chose automatic increment, it doesn't work anymore.
Problem using increment Month
- ProjectAxisIncrementMonth.zip
- (5.38 KiB) Downloaded 1746 times
- LabelBottomAxisIncrementAutomatique.png (16.55 KiB) Viewed 22614 times
- LabelBottomAxisIncrementMonth.png (50.3 KiB) Viewed 22615 times
Re: Problem using increment Month
The VCL project you've attached gives me a slightly different Javascript output for me: So I assume you modified it to get that result.
Yes, i've just changed the date format.
It's there a solution for this? It's very important and urgent for us.
You could reset the x values and the increment as follows:
for (var i=0; i<Series1.data.x.length; i++) {
Series1.data.x[i] = i;
Chart1.axes.bottom.increment=1;
