Hi, when a tip is shown for a point at the right edge of a chart, part of it can extend off the chart. This causes scroll bars to appear. Is there a way to control the positioning so that the tip always lies within the chart area?
Jim
ToolTip position
Re: ToolTip position
Hello Jim,
A change has been made for inclusion in the next update, to better clip the extreme Point Marks. It is not configurable though, or part of existing functionality, to move the Mark within the Axis bounds. It has been added as a feature request: http://bugs.teechart.net/show_bug.cgi?id=865
Hello Jim,
I thought I was going to be able to reproduce this easily but that hasn't been the case. Do you have a code snippet or example page you could point me to to better see the problem?
With thanks.
With thanks.
Marc, I get scroll bars because the chart occupies all of the containing <body>'s area. I can suppress the scroll bars by adding "overflow: hidden" to the body but there is still a positioning issue - the tip is not completely visible for the rightmost couple of bars.
Jim
Jim
- tmpBC11.zip
- (2.29 KiB) Downloaded 1559 times
Hello Jim,
Thanks, that made it clearer. I've sent a pre-release modification to your email address for you to evaluate. Please let us know if you were thinking of some other solution to the issue.
Thanks Marc. Unfortunately the message was deleted by our email filter as containing a virus. I'm guessing the .js file was not zipped? Could you resend and zip the attachment? Thanks.
Hello Jim,
The file was zipped but I've sent you another email with a link to a download.
