I add 3 points to simple line serie with X coordinates: 1, 1.5 and 2. Then I try to use onGetLabel to edit labels, but it seems that it doesn't fire for 1.5. Is it normal? If it is, how can I add custom label for point 1.5?
onGetLabel with fractions
Re: onGetLabel with fractions
I've tried this and the axis label at 1.5 seems to be correctly caught:
Are you using the latest TeeChart for JavaScript version?
Chart1=new Tee.Chart("canvas1");
var s = Chart1.addSeries(new Tee.Line(Chart1));
s.data.x=[1,1.5,2];
s.data.values=[1,2,2.5];
Chart1.axes.bottom.increment=0.5;
Chart1.axes.bottom.setMinMax(0.95, 2.05);
Chart1.axes.bottom.labels.ongetlabel=function(value,s) {
if (value==1.5) {
this.format.font.fill="red";
this.format.font.style="14px Verdana";
return "OneDotFive";
else {
this.format.font.fill="black";
this.format.font.style="11px Tahoma";
return s;
Chart1.draw();
The magic line was:
Now it works! Thank you for help!
I still don't get it. If I add point 1.7 to the line, it doesn't work for it. Setting Chart1.axes.bottom.increment to 0.1 doesn't help. Could you explain how onGetLabel works?
Hi Igor,
Debugging, I've seen the ongetlabel event was being fired, but value was 1.7000000000000006, not 1.7.
Changing the condition for this, it works fine for me:
s.data.x=[1,1.5,1.7,2];
s.data.values=[1,2.5,2,2];
Chart1.axes.bottom.increment=0.1;
var v=value.toFixed(trunc(value)==value ? 0 : this.decimals);
if ((v==1.5) || (v==1.7)) {
return s;
else {
return s;
Chart1.draw();
