Peter Carr
- Newbie
Post
by Peter Carr » Sun Jul 16, 2017 5:35 pm
To reproduce the issue, add a TChart to a FMX Multi-Device Application and insert the code below into the implementation section.
The code below adds two custom tick marks and labels to the TChart bottom axis and sets the axis labels to be large and red. It works fine in Delphi 10.1 Berlin with Teechart Pro v2017.21.170329 32 bit FMX. It does not work in Delphi 10.2 Tokyo with Teechart Pro v2017.22.170619 32 bit FMX, where the custom labels appear at default size and in black.
Is this a bug or am I doing something wrong. If a bug, is there a workaround until you fix it?
uses
FMXTee.Series, System.UIConsts;
procedure TForm3.FormCreate(Sender: TObject);
Chart1.View3D := False;
Chart1.Axes.Bottom.SetMinMax(1, 10);
Chart1.Axes.Bottom.Items.Add(2, '2');
Chart1.BottomAxis.Items.Add(5, '5');
// Make bottom axis tick labels big and red
Chart1.BottomAxis.LabelsFont.Size := 30;
Chart1.BottomAxis.LabelsFont.Color := claRed;
- Guru
Post
by Christopher » Mon Jul 17, 2017 1:28 pm
Many thanks for reporting this issue to us - it is a defect which I have added to our issue-tracking database with
id=1894. At the moment I cannot suggest a workaround for you, but if I discover one in the near future I will certainly pass it on to you.
Peter Carr
- Newbie
Post
by Peter Carr » Wed Aug 09, 2017 6:58 am
As a workaround, I have reverted to using the v2017.21 Teechart in Delphi 10.2 Tokyo. In other words, I am skipping v2017.22 due to this bug.
Post
by Sandra » Wed Aug 09, 2017 9:51 am
Hello Peter,
Many thanks for the information. I have added the information to the bug
id=1894.
Thanks in advance
