Using TPDFCanvas Directly
BruceC
Post by BruceC » Mon Mar 21, 2016 9:00 am
I am not using any TeeChart component. But create a TPDFCanvas in code as follows:
  PDF:=TPDFCanvas.Create;
  PDF.Document.Width:=842;
  PDF.Document.Height:=597;
  TTeeCanvas(PDF).Pen.Width:=ThickPen;
  PDF.DoHorizLine(42,800,100);  // 1st horizontal line
  TTeeCanvas(PDF).Pen.Width:=ThinPen;
  PDF.DoHorizLine(142,582,125);  // 2nd horizontal line
  PDF.DoHorizLine(42,800,150);  // 3rd horizontal line
  PDF.DoVertLine(42,100,400);   // 1st vertical line
  PDF.DoVertLine(102,100,360);  // 2nd vertical ine
  PDF.DoVertLine(142,100,400);  // 3rd vertical line
  PDF.Font.Family:='Helvetica';
  PDF.Font.Size:=14;
  PDF.Font.Color:=TAlphaColors.Black;
  PDF.TextAlign:=TA_LEFT;
  PDF.TextOut(350,20,'Anything');
 PDF.SaveToFile(S);
 PDF.DisposeOf;
This work perfectly running under windows but on Android and iOS it crashes with an access violation when calling the TextOut procedure. All of the other drawing of lines, etc. works fine.
I am using TeeChartVCL-2015.16. Is there something else that I should be initialising first?
BruceC
TeeSaveToPDFFile
Post by BruceC » Tue Mar 22, 2016 9:24 am
Text written using Canvas.TextOut is not shown on iOS, it shows fine on Android and Windows.
Also text shown as bold in the chart is not shown in the resultant PDF as bold.
Re: Using TPDFCanvas Directly
Post by Yeray » Tue Mar 22, 2016 11:42 am
Hello Bruce,
Have you solved the problem with the text in PDF in Android?
BruceC
Post by BruceC » Tue Mar 22, 2016 1:40 pm
I solved the first problem by programatically creating a TChart and writing to that in the OnAfterDraw event. With regard to the 2nd problem, no I haven't.
It works fine on Androidand WIndows but not iOS. No text is tisplayed at all. If I email the PDF generated to myself it is in the PDF and it views correctly on a WIndows PC. Must be something in the PDF that iOS does not like.
Post by Yeray » Tue Mar 22, 2016 2:48 pm
Hi Bruce,
I've merged both topic because they seem to talk about the same, isn't it?
BruceC wrote:I solved the first problem by programatically creating a TChart and writing to that in the OnAfterDraw event.
Could you please expand on how did you solve that?
It may help us to find a solution for the problem on iOS.
BruceC
Post by BruceC » Tue Mar 22, 2016 3:03 pm
I believe that it is because the fonts are not embedded in the PDF. Is there a way of forcing this?
I can now confirm that the PDF generated also has no visible text on OSX too.
Bruce
BruceC
Post by BruceC » Tue Mar 22, 2016 3:07 pm
Code:
  Chart1:=TChart.Create(Self);
  with Chart1 do
    Parent:=Self;
    AllowPanning:=TPanningMode.pmNone;
    BackWall.Brush.Color:=TAlphaColors.White;
    BackWall.Color:=TAlphaColors.White;
    BackWall.Visible:=False;
    BottomWall.Visible:=False;
    LeftWall.Visible:=False;
    Legend.Visible:=False;
//    Title.Text.Strings[1]:='EKM-Mobile Weekly Report';
    Title.Visible:=False;
    AxisVisible:=False;
    BottomAxis.Automatic:=False;
    BottomAxis.AutomaticMaximum:=False;
    BottomAxis.AutomaticMinimum:=False;
    BottomAxis.Axis.Visible:=False;
    BottomAxis.Grid.Visible:=False;
    BottomAxis.Labels:=False;
    BottomAxis.LabelsFormat.Visible:=False;
    BottomAxis.Title.Visible:=False;
    BottomAxis.Visible:=False;
    Panning.MouseWheel:=pmwNone;
    Shadow.Visible:=False;
    View3DOptions.Orthogonal:=False;
    View3DWalls:=False;
    Zoom.Allow:=False;
    Zoom.Brush.Kind:=TBrushKind.None;
    Zoom.Pen.Visible:=False;
    BevelOuter:=bvNone;
    Enabled:=False;
    TabOrder:=0;
    EnableDragHighlight:=False;
    Size.PlatformDefault:=False;
    Size.Width:=842;
    Size.Height:=597;
    OnAfterDraw:=Chart1AfterDraw;
procedure TEditMonitoringForm.Chart1AfterDraw(Sender: TObject);
const
  ThickPen=1.0;
  ThinPen=0.5;
  RepTitle='WEEKLY MONITORING';
  I,J:Integer;
  Query:TFDQuery;
  WeekCommencingDate:TDate;
  Tots,Vals:array[1..11] of Single;
  FName,Comments:String;
  FontList:TStringList;
  Inc(DrawCount);
//  Chart1.Canvas.Draw(700,15,Image1.Bitmap);
  Chart1.Canvas.Pen.Width:=ThickPen;
  Chart1.Canvas.DoHorizLine(42,800,100);  // 1st horizontal line
  Chart1.Canvas.Pen.Width:=ThinPen;
  Chart1.Canvas.DoHorizLine(142,582,125);  // 2nd horizontal line
  Chart1.Canvas.DoHorizLine(42,800,150);  // 3rd horizontal line
  Chart1.Canvas.DoVertLine(42,100,400);   // 1st vertical line
  Chart1.Canvas.DoVertLine(102,100,360);  // 2nd vertical ine
  Chart1.Canvas.DoVertLine(142,100,400);  // 3rd vertical line
  Chart1.Canvas.DoVertLine(182,125,400);  // 4th vertical line
  Chart1.Canvas.DoVertLine(222,125,400);  // 5th vertical line
  Chart1.Canvas.DoVertLine(262,125,400);  // 6th vertical line
  Chart1.Canvas.DoVertLine(302,125,400);  // 7th vertical line
  Chart1.Canvas.DoVertLine(342,125,400);  // 8th vertical line
  Chart1.Canvas.DoVertLine(382,125,400);  // 9th vertical line
  Chart1.Canvas.DoVertLine(422,100,400);  // 10th vertical line
  Chart1.Canvas.DoVertLine(462,125,360);  // 11th vertical line
  Chart1.Canvas.DoVertLine(502,100,360);  // 12th vertical line
  Chart1.Canvas.DoVertLine(542,125,360);  // 13th vertical line
  Chart1.Canvas.DoVertLine(582,100,360);  // 14th vertical line
  Chart1.Canvas.DoVertLine(800,100,360);  // 15th vertical line
  Chart1.Canvas.DoHorizLine(42,800,180);  // 4th horizontal line
  Chart1.Canvas.DoHorizLine(42,800,210);  // 5th horizontal line
  Chart1.Canvas.DoHorizLine(42,800,240);  // 6th horizontal line
  Chart1.Canvas.DoHorizLine(42,800,270);  // 7th horizontal line
  Chart1.Canvas.DoHorizLine(42,800,300);  // 8th horizontal line
  Chart1.Canvas.DoHorizLine(42,800,330);  // 9th horizontal line
  Chart1.Canvas.DoHorizLine(42,800,360);  // 10th horizontal line
  Chart1.Canvas.DoHorizLine(42,422,400);  // 11th horizontal line
  Chart1.Canvas.Font.Family:='Helvetica';
  Chart1.Canvas.Font.Size:=14;
  Chart1.Canvas.Font.Color:=TAlphaColors.Black;
  Chart1.Canvas.TextAlign:=TA_LEFT;
  Chart1.Canvas.Font.Style:=[TFontStyle.fsBold,TFontStyle.fsUnderline];
  Chart1.Canvas.TextOut(350,20,RepTitle);
//  Chart1.Canvas.DoHorizLine(((800-PDF.TextWidth(RepTitle)) div 2)+2,((800-PDF.TextWidth(RepTitle)) div 2)+
//    Chart1.Canvas.TextWidth(RepTitle)+2,17+PDF.TextHeight(RepTitle));  // Underline Title
  Chart1.Canvas.Font.Size:=11;
  Chart1.Canvas.Font.Style:=[TFontStyle.fsBold];
  Chart1.Canvas.TextOut(42,60,'Name:');
  Chart1.Canvas.TextOut(200,60,'Week commencing:');
  Chart1.Canvas.TextOut(500,60,'Weight at end of week:');
  Chart1.Canvas.TextOut(58,118,'Date');
  Chart1.Canvas.TextOut(111,118,'Day');
  Chart1.Canvas.TextOut(200,105,'Number of seizures of each type');
  Chart1.Canvas.TextOut(160,124,'1');
  Chart1.Canvas.TextOut(200,124,'2');
  Chart1.Canvas.TextOut(240,124,'3');
  Chart1.Canvas.TextOut(280,124,'4');
  Chart1.Canvas.TextOut(320,124,'5');
  Chart1.Canvas.TextOut(360,124,'6');
  Chart1.Canvas.TextOut(400,124,'7');
  Chart1.Canvas.TextOut(153,136,'Abs');
  Chart1.Canvas.TextOut(193,136,'Myo');
  Chart1.Canvas.TextOut(230,136,'Drop');
  Chart1.Canvas.TextOut(269,136,'Tonic');
  Chart1.Canvas.TextOut(313,136,'T/C');
  Chart1.Canvas.TextOut(348,136,'Focal');
  Chart1.Canvas.TextOut(388,136,'Other');
  Chart1.Canvas.TextOut(440,100,'Blood or');
  Chart1.Canvas.TextOut(429,111,'urine ketones');
  Chart1.Canvas.TextOut(526,100,'Blood');
  Chart1.Canvas.TextOut(520,111,'glucose');
  Chart1.Canvas.TextOut(434,130,'AM');
  Chart1.Canvas.TextOut(474,130,'PM');
  Chart1.Canvas.TextOut(514,130,'AM');
  Chart1.Canvas.TextOut(554,130,'PM');
  Chart1.Canvas.TextOut(620,104,'Comments on any illness or');
  Chart1.Canvas.TextOut(625,118,'changes to diet, activity or');
  Chart1.Canvas.TextOut(670,132,'<strong>medication</strong>',true);
  Chart1.Canvas.TextOut(90,373,'Total');
  Chart1.Canvas.Font.Style:=[];
  Chart1.Canvas.TextOut(111,157,'Sun');
  Chart1.Canvas.TextOut(111,187,'Mon');
  Chart1.Canvas.TextOut(111,217,'Tue');
  Chart1.Canvas.TextOut(111,247,'Wed');
  Chart1.Canvas.TextOut(111,277,'Thu');
  Chart1.Canvas.TextOut(111,307,'Fri');
  Chart1.Canvas.TextOut(111,337,'Sat');
  WeekCommencingDate:=IncDay(StartOfTheWeek(lblDate.TagFloat),-1);
  Query:=TFDQuery.Create(Nil);
  Query.Connection:=MainForm.FDConnection;
  for I:=1 to 11 do
    Tots[I]:=0;
  for I:=1 to 7 do
    Chart1.Canvas.TextOut(44,157+((I-1)*30),FormatDateTime('dd/mm/yyyy',IncDay(WeekCommencingDate,I-1)));
    Query.SQL.Text:='select * from MonitorDay where PatientID='+qPatients.FieldByName('ID').AsString+' and DayDate='+
      QuotedStr(FormatDateTime('YYYY-MM-DD',IncDay(WeekCommencingDate,I-1)));
    Query.Open;
    if Query.IsEmpty then
      Comments:='';
      for J:=1 to 11 do
        Vals[J]:=0;
    end else
      Comments:=Query.FieldByName('Comments').AsString;
      for J:=1 to 7 do
        Vals[J]:=Query.FieldByName('Seize'+IntToStr(J)).AsInteger;
      Vals[8]:=Query.FieldByName('KetonesAM').AsFloat;
      Vals[9]:=Query.FieldByName('KetonesPM').AsFloat;
      Vals[10]:=Query.FieldByName('GlucoseAM').AsFloat;
      Vals[11]:=Query.FieldByName('GlucosePM').AsFloat;
    for J:=1 to 7 do
      Tots[J]:=Tots[J]+Vals[J];
      Chart1.Canvas.TextOut(153+((J-1)*40),157+((I-1)*30),Format('%4d',[Round(Vals[J])]));
    for J:=8 to 11 do
      Chart1.Canvas.TextOut(155+((J-1)*40),157+((I-1)*30),Format('%3.1f',[Vals[J]]));
    if Comments<>'' then
      Chart1.Canvas.TextOut(584,157+((I-1)*30),Comments);
    Query.Close;
  for J:=1 to 7 do
    Chart1.Canvas.TextOut(153+((J-1)*40),373,Format('%4d',[Round(Tots[J])]));
  Query.DisposeOf;
  if DrawCount=1 then
    FName:=GetFullPathName('Weekly.pdf');
    if FileExists(FName) then
      DeleteFile(FName);
    TeeSaveToPDFFile(Chart1,FName,Round(Chart1.Width),Round(Chart1.Height));
//    DisplayPDFFile(FName);
    Chart1.Visible:=False;
Post by Yeray » Wed Mar 23, 2016 10:38 am
I could reproduce the problem thanks to your code so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1477
Feel free to add your mail to the CC list to be automatically notified when an update arrives.
BruceC
Post by BruceC » Wed Mar 23, 2016 11:59 am
Thanks. I need to be able to get this working asap for a childrens charity organization. Is there any way I can force the fonts to be included in the current version?
Post by Yeray » Wed Mar 30, 2016 10:30 am
Hello Bruce,
I'm sorry but I'm afraid I can't tell you when this will be fixed.
