Series Marks are shown partially when on the edge
Posted: Tue Dec 22, 2015 1:40 am
by 16573681
Good day,
I have an issue with the marks not displaying text when they are on the edge of the chart. Please see the screenshot.
The text of marks does not fit
The code could be found further below at the bottom of this post. The form contains an instance of the unmodified TChart (Chart1).
There is a .NET thread where the following solution has been offered:
FLineChart.Marks.Clip := False;
Chart1.MarginLeft := 10;
Chart1.MarginRight := 10;
Unfortunately this solution needs to be applied on the case by case basis. When the text of the mark is unknown upfront, this will not work.
unit MainUnit;
interface
uses
  System.SysUtils, System.Types, System.UITypes, System.Classes, System.Variants,
  FMX.Types, FMX.Controls, FMX.Forms, FMX.Graphics, FMX.Dialogs, FMXTee.Engine,
  FMXTee.Procs, FMXTee.Chart, FMXTee.Series, FMXTee.Canvas;
type
  TForm4 = class(TForm)
    Chart1: TChart;
  private
    FLineChart: TLineSeries;
  public
    { Public declarations }
var
  Form4: TForm4;
implementation
{$R *.fmx}
procedure TForm4.FormCreate(Sender: TObject);
var
  LDate: TDate;
  LDateText: string;
  Chart1.AllowPanning := TPanningMode.pmNone;
  Chart1.LeftWall.Dark3D := False;
  Chart1.Legend.Visible := False;
  Chart1.Title.Text.Text := '';
  Chart1.Title.Visible := False;
  Chart1.BottomAxis.Grid.Visible := False;
  Chart1.LeftAxis.Grid.Visible := False;
  Chart1.Shadow.Visible := False;
  Chart1.View3D := False;
  Chart1.View3DOptions.Orthogonal := False;
  Chart1.View3DWalls := False;
  Chart1.Zoom.Allow := False;
  Chart1.Zoom.Animated := True;
  Chart1.Zoom.Brush.Kind := TBrushKind.None;
  Chart1.Zoom.Direction := TTeeZoomDirection.tzdVertical;
  Chart1.BevelOuter := bvNone;
  Chart1.Hover.Visible := False;
  Chart1.BottomAxis.DateTimeFormat := 'yyyy';
  Chart1.BottomAxis.LabelStyle := talNone;
  Chart1.LeftAxis.LabelStyle := talNone;
  FLineChart := TLineSeries.Create(Chart1);
  Chart1.AddSeries(FLineChart);
  FLineChart.Marks.Arrow.Visible := True;
  FLineChart.Marks.ShapeStyle := fosRoundRectangle;
  FLineChart.Marks.Visible := True;
  FLineChart.Marks.Shadow.Visible := False;
  FLineChart.Marks.Emboss.Visible := False;
  FLineChart.Marks.Pen.Style := TPenStyle.psClear;
  FLineChart.Marks.Callout.ArrowHead := ahSolid;
//  FLineChart.Marks.Clip := False;
  FLineChart.LinePen.Width := 2;
//  Chart1.MarginLeft := 10;
//  Chart1.MarginRight := 10;
//  Chart1.MarginTop := 10;
//  Chart1.MarginBottom := 10;
  LDateText := '01/11/2015';
  LDate := StrToDate(LDateText);
  FLineChart.AddXY(LDate, 300, '');
  FLineChart.Marks[0].Text.Add('Long hint text to display.');
  FLineChart.Marks[0].Text.Add('It does not fit.');
  LDateText := '06/11/2015';
  FLineChart.AddXY(LDate, 300, LDateText);
  LDateText := '09/11/2015';
  LDateText := '14/11/2015';
end.
Re: Series Marks are shown partially when on the edge
Posted: Tue Dec 22, 2015 9:07 am
The issue here is with the margins, not with the marks clipping.
If I simplify your example to the minimum and add two checkboxes to test the margin and the marks clip:
procedure TForm1.CBMarginsClick(Sender: TObject);
  if CBMargins.Checked then
    Chart1.MarginLeft := 15;
    Chart1.MarginRight := 5;
    Chart1.MarginTop := 12;
    Chart1.MarginBottom := 4;
  end
    Chart1.MarginLeft := 3;
    Chart1.MarginRight := 3;
    Chart1.MarginTop := 4;
procedure TForm1.CBMarksClipClick(Sender: TObject);
  Chart1[0].Marks.Clip:=CBMarksClip.Checked;
  Chart1.BottomAxis.Visible:=false;
  Chart1.LeftAxis.Visible:=false;
    FillSampleValues(5);
  Chart1.Walls.Back.Gradient.StartColor:=RGB(255, 128, 0);
  Chart1.Gradient.StartColor:=clBlack;
  Chart1.Gradient.MidColor:=clNone;
You get something like this when I run it:
Note the orange rect is the ChartRect; this is the area delimited by the axes, where the series are drawn.
And the black area behind is the whole TChart component. Note TChart can't draw anything out of this area.
If you set the series marks clipping, the marks will be clipped in the ChartRect area:
Instead, what you probably want is to increment the margins to fit the marks into the TChart component:
