XE7: TChart on FMX TabControl hangs using "slide" animation
Posted: Mon Oct 20, 2014 6:44 pm
by 16569249
If a TeeChart component that is on a hidden page of a tab control becomes active but using the TabControl's "SetActiveTabWithTransition" with "TTabTransition.Slide".
Using the attached demo, make sure "TabItem1" is the selected tab at design-time; Run the app; click "Button2" to active "TabItem2" with the "Slide" animation; The App will hang.
If the "Chart1" is made visible by either setting "TabItem2" as selected at design-time, or by clicking "TabItem2" directly at run-time, then the "slide" transition will work (won't hang the app) from then on.
I have an Mobile (iOS) app that was developed on XE3 that has multiple TeeChart components on pages of TabControls that use the slide transition to move between the tabs/pages. I converted/upgraded this project to XE4, XE5, and then to XE6 with no problems.
In hindsight, I've always noticed a curious pause (1 to 2 secs) the *first* time a page with a TeeChart component is "slide" animated in - it's been there since the first version using XE3.
Re: XE7: TChart on FMX TabControl hangs using "slide" animation
Posted: Tue Oct 21, 2014 3:21 pm
I could reproduce the problem and we're investigating it.
We'll be back to you here asap.
Posted: Wed Oct 22, 2014 9:39 am
I've reproduced the problem and I've seen the error is a bit different with the actual sources we use here. I've added a ticket to the public tracker you can follow:
http://bugs.teechart.net/show_bug.cgi?id=974
Posted: Wed Oct 22, 2014 2:37 pm
Hi again,
Just to let you know we just fixed it in the internal sources we have here so the next maintenance release should allow you to do this without problems.
Posted: Wed Oct 29, 2014 5:58 pm
by 16569249
Excellent! Thank you for your attention to this. Could you give me a rough guess as to when that maintenance release will be available?
Posted: Mon Nov 03, 2014 10:17 am
dolson wrote:Could you give me a rough guess as to when that maintenance release will be available?
I'm afraid I can't tell you this.
However, I see you are a source code customer so I'll send a link to the latest beta sources to the mail account you have registered in this forum.
