Trying to implement panning/scroling
Posted: Sun Jun 29, 2014 5:15 pm
by 17568804
Hi all.
As I want more control about panning, and as the default panning provided doesn't work well, I tried to implement panning myself using gestures in FireMonkey. Here is what I got so far for the X axis only:
procedure TMultiEPGFrame.FrameGesture(Sender: TObject;
  const EventInfo: TGestureEventInfo; var Handled: Boolean);
var
  lGlobalWidth: Double;
  lLocalWidth: Double;
  if EventInfo.GestureID = igiPan then
    lGlobalWidth := self.Width;
    lLocalWidth := fChart.BottomAxis.Maximum - fChart.BottomAxis.Minimum;
    if fLastPosition.X < EventInfo.Location.X then
      fChart.BottomAxis.Minimum := fChart.BottomAxis.Minimum -
        ((EventInfo.Location.X) / lGlobalWidth);
      fChart.BottomAxis.Maximum := fChart.BottomAxis.Maximum -
    end
      fChart.BottomAxis.Minimum := fChart.BottomAxis.Minimum +
      fChart.BottomAxis.Maximum := fChart.BottomAxis.Maximum +
    fLastPosition := EventInfo.Location;
I basically adjust the maximum and minimum of my X axis approximately by the amount my finger goes left or right ... If anyone has a better suggestion, I am all ears!
Thanks a lot!
CJ
Re: Trying to implement panning/scroling
Posted: Tue Jul 01, 2014 10:57 am
Hi CJ,
This seems to be related to this thread.
As Pep said there, setting the Left button as the ScrollMouseButton should make the default scoll feature usable in mobile applications.
Posted: Tue Jul 01, 2014 5:58 pm
by 17568804
Yes, thanks this works - one more question though also asked in the other thread:
How do I block panning/scrolling to work inside some arbitrary bounds only?
Cheers,
CJ
Posted: Tue Jul 01, 2014 8:57 pm
by 17568804
This is a solution I implemented which works:
http://www.teechart.net/support/viewtop ... 661#p66661
Posted: Wed Jul 02, 2014 7:22 am
Hi CJ,
We'll reply you in the other thread as soon as possible.
There's no need to maintain two threads with the same questions and answers.
