Is there a OnMarkClick() event?
elmec
Post by elmec » Wed Jun 11, 2014 1:50 am
I am using TPointSeries with setting the Marks visible.
And I want to do sth. when Marks clicked,
is there some event like OnMarkClick()?
Re: Is there a OnMarkClick() event?
Post by Yeray » Wed Jun 11, 2014 9:38 am
There's a clicked function for the Marks, so you could use the Chart's OnMouseDown event as follows:
  Shift: TShiftState; X, Y: Single);
  Caption:=IntToStr(Chart1[0].Marks.Clicked(Round(X), Round(Y)));
elmec
Post by elmec » Sun Jun 15, 2014 2:38 am
Thank you.
And one more question about TAxisArrowTool.
I want to know if TChart or TAxisArrowTool is doubleclicked.
And the events were triggled as below when the TAxisArrowTool doubleclicked.
So I set a flag for TAxisArrowToolClick (1), then check the flag when Chart1DblClick (2) triggled,and clear the flag.
But the flag is set again by (3).. so if I doubleclicked the TChart after (3), it result in that TAxisArrowTool was doubleclicked..
Is there any better idea?
Chart1DblClick              (2)
TAxisArrowToolClick      (3)
Post by Yeray » Mon Jun 16, 2014 11:18 am
elmec wrote:And one more question about TAxisArrowTool.
I've done a simple tests, and adding a boolean variable as follows I seem to be able to check when the arrow has been doubleclicked:
var dbClick: bool=false;
procedure TForm1.Chart1Click(Sender: TObject);
  dbClick:=false;
  Memo1.Lines.Add('Chart Click');
procedure TForm1.Chart1DblClick(Sender: TObject);
  dbClick:=true;
  Memo1.Lines.Add('Chart DblClick');
procedure TForm1.ChartTool1Click(Sender: TAxisArrowTool; AtStart: Boolean);
  if dbClick then
    Memo1.Lines.Add('Arrow DblClick');
    dbClick:=false;
  end
    Memo1.Lines.Add('Arrow Click');
This sounds as a completely different question. Please, try to create different threads for different questions as indicated in the instructions in my signature.
elmec
Post by elmec » Tue Jun 17, 2014 2:29 am
Thank you.
But I also want to do sth.
when just doubleclicking the TChart, not the TAxisArrowTool,
so I want to know which is doubleclicked when TChartDblClicked event triggled.
elmec
Post by elmec » Tue Jun 17, 2014 2:32 am
In a word, I want to do sth. as below in Chart1DblClick function.
void __fastcall TForm12::Chart1DblClick(TObject *Sender)
	if (AxisArrowClicked)
		do sth.
		do sth.
Post by Yeray » Tue Jun 17, 2014 1:04 pm
You can play further with the events to find what you are looking for.
If I understand you correctly, this would achieve it:
var chartClicked: bool=false;
    chartDblClicked: bool=false;
    arrowClicked: bool=false;
    arrowDblClicked: bool=false;
    myMouseDown: TPoint;
  Chart1.Pages.MaxPointsPerPage:=5;
  chartDblClicked:=false;
  arrowDblClicked:=false;
  chartClicked:=true;
  chartDblClicked:=true;
  if chartDblClicked then
    arrowDblClicked:=true;
  end
    arrowClicked:=true;
    chartClicked:=false;
  myMouseDown.X:=X;
  myMouseDown.Y:=Y;
  if chartClicked then
    Memo1.Lines.Add('Chart Clicked');
  if arrowClicked then
    Memo1.Lines.Add('Arrow Clicked');
    Memo1.Lines.Add('Chart Double Clicked');
  if arrowDblClicked then
    Memo1.Lines.Add('Arrow Double Clicked');
  arrowClicked:=false;
