PrintPreview Standard FireMonkey
Posted: Sat Oct 26, 2013 11:18 pm
by 16867595
Can I call the PrintPreview or something like this with TChart Standard on XE4 Firemonkey desktop application???
(2013.08.130430 32bits FMX)
Re: PrintPreview Standard FireMonkey
Posted: Mon Oct 28, 2013 8:38 am
by narcis
You should try doing as explained
here using FMXTee prefixed units instead.
Posted: Wed Oct 30, 2013 3:05 am
by 16867595
Thanks for the help.
This worked to show the preview print:
uses FMXTee.Print.Preview and TChartPreview.Preview(Self, Chart1);
But..... I got another problem. The preview window opens with all black (see the print screen).
Your suggestion didn“t work.
- PrintPreview.jpg (40.96 KiB) Viewed 16465 times
Posted: Thu Oct 31, 2013 4:01 pm
Are you sure you are using the Standard version? This doesn't work for me.
uses FMXTee.Print.Preview;
Could you please arrange a simple example project we can run as is to reproduce the black dialog in the picture?
Posted: Mon Nov 04, 2013 12:26 pm
by 16867595
There is:
unit Unit1;
interface
uses
System.SysUtils, System.Types, System.UITypes, System.Rtti, System.Classes,
System.Variants, FMX.Types, FMX.Controls, FMX.Forms, FMX.Dialogs,
FMX.StdCtrls, FMXTee.Engine, FMXTee.Procs, FMXTee.Chart, FMXTee.Series, FMXTee.Print.Preview;
type
TForm1 = class(TForm)
Chart1: TChart;
Button1: TButton;
Series1: TLineSeries;
procedure FormShow(Sender: TObject);
private
{ Private declarations }
public
{ Public declarations }
var
Form1: TForm1;
implementation
{$R *.fmx}
procedure TForm1.FormShow(Sender: TObject);
var
I: Integer;
for I := 0 to 200 do
Chart1.Series[0].AddY(Random(1000));
end.
Thanks!
- Imagen1.jpg (365.6 KiB) Viewed 16400 times
- Imagen3.jpg (249.11 KiB) Viewed 16400 times
Posted: Tue Nov 05, 2013 11:28 am
by narcis
I can not reproduce this with TeeChart Pro FMX build 2013.08.130521 (latest maintenance release available) nor with the
current beta. Can you please check if 2013.08.130521's eval version or the beta solve the problem at your end? Otherwise, you might expect the issue being fixed for the next maintenance release due out by the end of this week or next week the latest.
