TChart and iOS on XE4
Posted: Wed Jun 12, 2013 9:04 pm
by 16566186
I'm developing an App using TChart for iOS, when I use the component on a Blank Application template the chart is displayed with no problems, but when I use a Header/Footer with Navigation template, and place the TChart component on the second tab of the TabControl, the chart is not drawn Ok.
I have attached an Image.
Thanks in advance,
Omar Zelaya
Re: TChart and iOS on XE4
Posted: Thu Jun 13, 2013 10:44 am
by narcis
Hi Omar,
I don't have Macintosh at hand right now to test the issue. We will test it ASAP. In the meantime, It works fine for me running it with 32-bit Windows as target platform though. Does this work fine for you in Win32?
Posted: Thu Jun 20, 2013 10:34 am
by narcis
Hi Omar,
I have tested this in an iOS Simulator and worked fine as well:
Does this work fine at your end? I'm using RAD Studio XE4 with Update 1. If the problem persists please attach a simple example project we can run "as-is" to reproduce the problem here.
