Speed IOS
jls
Speed IOS
Post by jls » Wed Jun 13, 2012 10:23 am
Hello
Series is created like this
chart.addseries(TBarSeries)
chart.series[0].fillsamplevalues(9)
First:
I get the same error as in
http://www.teechart.net/support/viewtop ... 17&t=13316
I tried to do this
http://qc.embarcadero.com/wc/qcmain.aspx?d=103976
but I don't think my changes is used by the compiler.
Must I do something else than modify the file?
Can the modified file be located in the project folder?
Main Issue:
but the main issue is the speed on my ipad/iphone
everything is slow (5+ seconds)
loading, zooming, rotation
any idea whats wrong?
using XE2 update 4 with fix
Jørgen
Re: Speed IOS
Post by Yeray » Wed Jun 13, 2012 2:31 pm
Hi Jørgen,
jls wrote:First:
viewtopic.php?f=17&t=13316
I tried to do this
Correcting these functions in the FMX_Types_FPC_Impl.inc file from "\Embarcadero\RAD Studio\9.0\source\fmi" should be enough:
function TRectF.GetBottomRight: TPointF;
  //Result := TPointF.Create(Bottom, Right);  //Act
  Result := TPointF.Create(Right, Bottom);  //Exp
function TRectF.GetTopLeft: TPointF;
  //Result := TPointF.Create(Top, Left);  //Act
  Result := TPointF.Create(Left,Top);  //Exp
jls wrote:Main Issue:
I'd suggest you to take a look at this thread, where we discussed about the speed on iOS
http://www.teechart.net/support/viewtop ... 17&t=13120
jls
Re: Speed IOS
Post by jls » Thu Jun 14, 2012 7:54 am
Hello
My problem is simple to reproduce
FChart := TChart.Create(Self);
FChart.AddSeries(TBarSeries);
// FChart.Align := TAlignLayout.alClient;
FChart.Width := 400;
FChart.Height := 400;
FChart.Series[0].FillSampleValues(9);
FChart.Parent := self;
The problem is then I try to rotate the device.
It works OK on IPad simulator
but on the IPad it is very slow 5 sec.
It rotates fast, but the scaling after rotation uses 5 sec.
(still have problems with the bug fix, added this to a new posting)
Jørgen
Re: Speed IOS
Post by Yeray » Fri Jun 15, 2012 11:55 am
Hi Jørgen,
As you can read here, we are aware that the speed on the real devices is slower.
Have you tried the tips on the last message?
jls
Re: Speed IOS
Post by jls » Fri Jun 15, 2012 12:16 pm
I have not tried it, will do this
How much better should it be?
Do you think you will solve the performance issue?
If so, do you have an estimated date?
Jørgen
Re: Speed IOS
Post by Yeray » Fri Jun 15, 2012 1:35 pm
Hi Jørgen,
jls wrote:I have not tried it, will do this
We'll be pleased to hear about your experience.
jls wrote:How much better should it be?
As Narcís said,
Narcís wrote:It helped slightly increasing performance here.
I'm afraid we haven't quantified it.
jls wrote:Do you think you will solve the performance issue?
I hope so! As you've noticed, taking some seconds for each repaint it's too much. But as you'll understand, I can't tell you how the improvements will change the performance before finding them.
I can't tell you a date either.
jls
Re: Speed IOS
Post by jls » Mon Jun 18, 2012 10:48 am
It did not help
It takes 20 seconds to rotate the chart on my IPad3.
Are you able to reproduce this?
Jørgen
program chart2;
uses
FMX_Forms,
Unit1 in 'Unit1.pas' {Form1},
FMX_Types;
{$R *.res}
GlobalUseHWEffects:=False;
GlobalDisableFocusEffect:=True;
GlobalUseDirect2D:=False;
GlobalUseDirect2DSoftware:=True;
Application.Initialize;
Application.CreateForm(TForm1, Form1);
Application.Run;
end.
Re: Speed IOS
Post by Sandra » Thu Jun 21, 2012 3:37 pm
Hello jls,
I think it is not a problem directly of TeeChart, so is a problem mostly of the behavior of Firemonkey in the iOS. We find many links that talk about this slowness of Firemonkey projects in iOs:
https://forums.embarcadero.com/message. ... 2&tstart=0
https://newsgroups.embarcadero.com/mess ... 3&tstart=0
Also, the Ipad is slower than Mac, so it get worse the situation.
I am sorry, but we cannot do any thing until developers of Firmonkey don't improve its performance in iOs.
X-Ray
Re: Speed IOS
Post by X-Ray » Fri Jun 22, 2012 6:47 am
Hello Sandra,
did you put an example application as bug report into QC?
It would be nice to have it there and trace if something is done on this important "feature".
best regards,
X-Ray
jls
Re: Speed IOS
Post by jls » Fri Jun 22, 2012 7:54 am
QC
106610
Re: Speed IOS
Post by Sandra » Fri Jun 22, 2012 9:49 am
Hello X-Ray and jls,
Firmonkey is very new, but seems announcements of Embarcadero about XE3 improve this type of problems. We should be waited Embarcadero publish beta version of XE3, to check it.
