yesterday I installed the latest XE2 Update 4 which was offered automatically by the IDE. After installation I received errors on starting the IDE. After some research I found out that there is a problem with the TeeChart libraries and the XE2 libraries "fmi161.*" and "fmx161.*". The reason is that these libraries no longer exists in XE2. They are now shifted to "fmi162.*" and "fmx162.*". A simple renaming leads to other problems because the libraries interfaces where obviously changed.
Is there allready a solution to that probnlem?
Kind regards
Markus
XE2 Update 4
Re: XE2 Update 4
Hi Markus,
TeeChart sources need to be recompiled for update 4. If you are source code customer you can already do that with the existing source code version. Otherwise you'll have to wait until we publish the binary installers for update 4, which we expect to be soon.
Re: XE2 Update 4
Hi Narcis,
thanks! It worked!
Greetings
Markus
thanks! It worked!
Greetings
Markus
Re: XE2 Update 4
We've just published the TeeChart v2012.05 installer supporting XE2 Update 4.
http://www.teechart.net/support/viewtop ... 118#p57118
