I keep getting three error messages from Rad Studio 10.2.2 after installation of TeeChart Pro VCL FMX 2017.10.23. I have made sure older versions were uninstalled, etc., and have tried re-installing several times.
The messages indicate "The procedure entry point @System@Net@Httpclient@Win@TWinHttpLib@$bcctr$qqrv could not be located in the dynamic link library C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX 2017.23\Delphi25\Delphi25.win32\Bin\DclFMXTreePro925.bpl" and the others are similar (one says the procedure entry point can't be located in FMXTeeImport925.bpl and the other that it can't load the package DclFMXTeePro925.bpl.
Any suggestions appreciated!
TeeChart Pro VCL FMX 2017.10.23 and Rad Studio 10.2.2
Re: TeeChart Pro VCL FMX 2017.10.23 and Rad Studio 10.2.2
Hello Polutropon,
Seems is the problem with Rad Studio Version. Would be inform you that if you want work without problems you must install Rad Studio 10.2.2 with the Hotfix. The specifically version is: RAD Studio 10.2 Version 25.0.29039.2004. Could you confirm us if it is the version as you use? Remember you find the information opening the Rad Studio and going to Menu Help->About Embarader Rad Studio.
Thanks in advance
Thanks in advance
Thanks for the information. I am on RAD Studio 10.2 Version 25.0.27659.1188 so will need to hunt down the hot fix you mentioned. Thanks!
