Legend, show Series Name and Series Total Value
I have attached my chart. How can I change the legend to show the Series Name along with the Total value of the Series?
- 2017-03-15_1212.png (43.43 KiB) Viewed 21988 times
Re: Legend, show Series Name and Series Total Value
You could use OnGetLegendText event. Ie:
procedure TForm1.Chart1GetLegendText(Sender: TCustomAxisPanel;
LegendStyle: TLegendStyle; Index: Integer; var LegendText: string);
var i: Integer;
if Index<Chart1.SeriesCount then
LegendText:=LegendText + ' $' + FormatFloat('#,##0.##', Chart1[Index].YValues.Total);
Thank you. I'll give it a shot.
I have another question along this same lines. I have a pie chart of categories (Attached). If transactions don't have any assigned category, the legend just displays the amount. I would like to add the text 'No Categories' in front of the amount but I can't seem to format it the way it is in the legend (Text left justified and amount right justified).
- 2017-07-13_1028.png (29.42 KiB) Viewed 21787 times
In case you are adding the values connecting the series to a dataset, you can loop your values and set the label at those points with empty labels. Ie:
I'm not sure to understand why don't you add the uncategorized value as you do with the others, with the "No Categories" label. Ie:realsol wrote:I have another question along this same lines. I have a pie chart of categories (Attached). If transactions don't have any assigned category, the legend just displays the amount. I would like to add the text 'No Categories' in front of the amount but I can't seem to format it the way it is in the legend (Text left justified and amount right justified).
Series1.Add(316560, 'No Categories');
if Series1.Labels[i] = '' then
Series1.Labels[i]:='No Categories';
Thanks. I ended up using the OnGetLegendText for the Chart and added
Worked perfectly. Thanks.
if Series1.Labels[Index] = '' then
Series1.Labels[index]:='No Categories';
