SaveChartToStream not found in FMX
JCG_NL
Post by JCG_NL » Fri Mar 10, 2017 10:45 am
Hi, I am using Teechart standard 2016 19 with Delphi Seattle in an FMX application
I did put FMXTee.Store in the uses clause.
The SaveChartToStream is not found.
What do I do wrong?
Re: SaveChartToStream not found in FMX
Post by Yeray » Mon Mar 13, 2017 10:59 am
Check the paths.
I've tried to reproduce the problem with a new simple FMX application. I've only dragged a TButton, a TPanel and two TCharts (one of the charts on the form and the second on the panel).
Here the code I tested:
uses FMXTee.Store, FMXTee.Constants, FMXTee.Series;
  Chart1.AddSeries(TBarSeries).FillSampleValues;
  RegisterTeeStandardSeries;
var tmpStream: TMemoryStream;
  tmpStream:=TMemoryStream.Create;
  SaveChartToStream(Chart1, tmpStream);
  tmpStream.Position:=0;
  LoadChartFromStream(Chart2, tmpStream);
And I got two exact charts after pressing the button:
