error installation Pro VCL FMX
radberlin
Post by radberlin » Tue Feb 14, 2017 7:38 am
Hello all,
During Installation of TeeChart Pro VCL FMX Source Code 2016.19 we onserved that procedure failed for some IDEs :
I am writing below the IDEs and the fatal errors that came up:
-iOS Device 32bit (Fatal error F2048 when trying to compile FMX.Tee.Gauges.Knob.pas)
-iOS Device 64bit (Fatal error F2048 when trying to compile FMX.Tee.Rose.pas)
-Android (Fatal error F2048 when trying to compile FMX.Tee.Editor.Export.PDF.pas)
The rest ones like Windows 32/64bit, MACOS & iOS Simulator compiled successfully.
Is there any help for this?
BR.
Re: error installation Pro VCL FMX
Post by Yeray » Tue Feb 14, 2017 9:39 am
What IDE are you compiling the sources for? Do you have all the updates installed in it?
radberlin
Post by radberlin » Tue Feb 14, 2017 1:30 pm
Hello Yeray,
We want to compile the source for RAD Studio Delphi Berlin 10.1.
Also all updates have been installed.
Post by Yeray » Wed Feb 15, 2017 7:33 am
The v2016.19 Pro with sources compiles and installs fine for us here on RAD 10.1 Berlin Update 2.
Have you modified the sources? Have you tried to run TeeRecompile "as administrator"?
radberlin
Post by radberlin » Wed Feb 15, 2017 8:04 am
Hi again!
This time I tried to run as administrator the TeeChart Recompilation tool as you proposed.
The error is still visible.
Check the image below.
error
Regarding the source files , we have not modified anyone ad to be sure we run the process in another laptop (second license) and still the same.
radberlin
Post by radberlin » Wed Feb 15, 2017 8:48 am
One more thing,
I tried to uninstall TeeChart , install it again (run as admin) and then recompile (as admin).
Behavior was the same. :roll:
Is there any case, any of the options & packages for compilation (in our case I have checked all of them) could create any conflict?
Also, I observed that when tool starts to compile each one of ios/android devices, gui often stucks and window appears like "not responding).
Lets say that for now we can do our job with compilation files for win32/64 , macos and ios simulator: Is there any possibility that this failed compilation has left any unwanted staff ?
BR
Post by Yeray » Wed Feb 15, 2017 11:54 am
radberlin wrote:Is there any case, any of the options & packages for compilation (in our case I have checked all of them) could create any conflict?
I could reproduce the fatal error you are reporting selecting "Debug packages compilation".
I found another error arises if you select "Decision Cube".
We'll investigate these problems.
radberlin wrote:Also, I observed that when tool starts to compile each one of ios/android devices, gui often stucks and window appears like "not responding).
The window usually hangs for me too (the compilations for the mobile platforms are quite slow), but it gets responsive again if you let the process finish.
SoftCho2017
Post by SoftCho2017 » Tue Jul 25, 2017 6:05 pm
Hi My name is José luis. I am to installing the software teecchart Pro VCL/ FMX but that the end of instalation show me the next window. I would like to use this tool for complet to visual studio 2017 some one tell me what is the reason?. Thanks
error window
Captura error teechart.JPG (40.45 KiB) Viewed 23190 times
Post by Yeray » Wed Jul 26, 2017 6:12 am
Hello José Luis,
SoftCho2017 wrote:I would like to use this tool for complet to visual studio 2017
I guess you are interested in TeeChart .NET, not TeeChart VCL/FMX.
