Drawing bitmap on Windows
Atmapuri
Post by Atmapuri » Wed Nov 27, 2013 10:47 am
Hi!
I am drawing a bitmap on TeeChart in FireMonkey for Windows:
var FBitmap: FMX.Graphics.TBitmap;
ParentChart.Canvas.StretchDraw(Rf,FBitmap)
The bitmap gets drawn, but the FBitmap.PixelFormat Property is ignored. The bitmap is drawn in the CMYK color mode it seems. (At least those are the colors I get to see). How can I get 4 byte RGB color format Bitmap displayed by TeeChart property?
Specifically:
TPixelFormat.pfA8R8G8B8;
Second: What to do to make the same code work on iOS, Android and OSx.
Thanks!
Atmapuri
Re: Drawing bitmap on Windows
Post by Narcís » Wed Nov 27, 2013 3:00 pm
Hi Atmapuri,
We need to investigate this thoroughly. TeeChart only calls Firemonkey's:
  FCanvas.DrawBitmap(Graphic,TeeRect(0,0,Graphic.Width,Graphic.Height),
                     ARect,Opacity,FStretchQuality=sqLow);
New Chart1.Canvas.StretchQuality property controlls last parameter at the signature above. At Quality Central there are several open bugs aboug DrawBitmap.
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
Atmapuri
Post by Atmapuri » Fri Nov 29, 2013 3:05 pm
Dear Narcis,
Any example would do fine, where you can do:
bitmap.Size(2,2);
bitmap.Map(...,bitData);
P := bitData.Scanline[0];
P[0].A := 12;
P[0].R := 25;
P[0].G := 36;
P[0].B := 50;
P[1]...
bitmap.Unmap(...);
tChart.Canvas.StretchDraw(bitmap, tChart.ClientRect);
Thanks!
Atmapuri
David Berneda
Post by David Berneda » Mon Dec 02, 2013 11:25 am
Hi Atmapuri
Just did the attached test project and it looks fine to me (both with high and low stretch blending modes).
regards
david
StretchBitmap.zip
(4.49 KiB) Downloaded 2424 times
Atmapuri
Post by Atmapuri » Fri Dec 06, 2013 8:22 pm
Dear David,
Thank you for the example. However, in the question there is specifically mentioned the Scanline. I cannot use SetPixel, because it is orders of magnitude too slow.
Do you always use SetPixel with FireMonkey? That would mean that you have not figured out how to work with Scanline yet either?
Thanks!
Atmapuri
David Berneda
Post by David Berneda » Tue Dec 10, 2013 11:43 am
There are several usages of ScanLine already in FireMonkey TTeeCanvas, of course.
I've changed the example using scanline, same (ok) results, see below.
TeeCanvas StretchDraw simply passes the bitmap to FireMonkey's DrawBitmap method, there is nothing changed:
procedure TTeeCanvas3D.StretchDraw(const ARect: TRect; const Graphic: TGraphic);
regards
david
var P : PAlphaColorArray;
b:=TBitmap.Create(2,2);
if b.Map(TMapAccess.maWrite,tmp) then
try
P:=tmp.GetScanline(0);
P[0]:=TAlphaColors.Red;
P[1]:=TAlphaColors.Green;
P:=tmp.GetScanline(1);
P[0]:=TAlphaColors.Blue;
P[1]:=TAlphaColors.Yellow;
tmp.SetPixel(0,0,TAlphaColors.Red);
tmp.SetPixel(0,1,TAlphaColors.Green);
tmp.SetPixel(1,0,TAlphaColors.Blue);
tmp.SetPixel(1,1,TAlphaColors.Yellow);
finally
b.Unmap(tmp);
Chart1.DelphiCanvas.BeginScene;
Chart1.Canvas.StretchDraw(Chart1.AbsoluteRect,b);
Chart1.DelphiCanvas.EndScene;
Atmapuri
Post by Atmapuri » Thu Jan 02, 2014 4:47 pm
Hello David,
The problem was resolved after I learned that:
1.) The Alpha field in RGB needs to be set to $FF (not transparent).
2.) The structure for the color has reversed storage format, Instead of RGB for VCL (24bit), it is ABGR for Firemonkey. (32 bit)
Because I was constructing colors from scratch I lost my compass for a while.
It took some time to make the code work with Alpha values of each color set to $FF.
Thanks for the assistance.
Kind Regards!
Atmapuri
