I was running the Recompile application when this error happenned :
EXCEPTION:
Cannot copy file: C:\Program Files\Steema Software\TeeChart Standard 2012 Source Code\TeeRecompile.exe to C:\Program Files\Steema Software\TeeChart Standard 2012 Source Code\Sources\CompiledStandard\Delphi16.win32\TeeInstall.exe
Error Code: 5 Description: Access Denied
What should i do now to correct this ?
teerecompile.exe to teeinstall.exe
Re: teerecompile.exe to teeinstall.exe
did you run the Recompile tool as Admin? (Right click: Run as adminstrator)
best regards,
X-Ray
best regards,
X-Ray
No, thank you, everything's okay now.
