Line width bug?
TeeChart for PHP
rustydiver
Line width bug?
Post by rustydiver » Thu May 02, 2013 9:56 pm
I shall try to be clear..
I have 3 lines, if I set all to solid, I can change the line width for each idependent of the others, but if I change styles to non-solid lines, funny things happen that reflect line width being held captive.
Example:
Line1 dash
Line1 width 3
Line2 dashdot
Line2 width 1
Line3 dot
Line3 width 1
This results in Lines 2 and 3 displaying at a width of 3 per Line 1, regardlesss instruction otherwise.
Example2:
Line1 solid
Line1 width 3
Line2 dashed
Line2 width 3
Line3 dot
Line3 width 1
This results in Line 3 displaying at a width of 3 per Line 2
Example3:
Line1 dot
Line1 width 3
Line2 dashed
Line2 width 1
Line3 solid
Line3 width 2
This results in Line 2 displaying at a width of 3 per Line 1
Example4:
Line1 dot
Line1 width 1
Line2 dashed
Line2 width 1
Line3 dashdot
Line3 width 3
This results in Line 1, Line 2, and Line 3 displaying as specified.
Example5:
Line1 dot
Line1 width 1
Line2 solid
Line2 width 3
Line3 dash
Line3 width 1
This results in Line 3 displaying at a width of 3 per Line 2 even though Line 2 is set as solid.
And etc., etc.
The line width is being carried over, and I have echoed my variables out right before and after the line code and they are correct. This only occurs for a line set as non-solid that occurs in code after another line. The width instructed is ignored and the lower-in-code Line carries the greater width set by another higher in the code.
Re: Line width bug?
Post by Yeray » Mon May 06, 2013 1:28 pm
You are right. I've added it to the wish list to be revised for next releases (TF90016564).
Thanks for reporting it.
rustydiver
Re: Line width bug?
Post by rustydiver » Mon May 06, 2013 1:51 pm
It is much needed soon for line discrimination with monochrome printing.
Thanx..
Re: Line width bug?
Post by Yeray » Tue May 07, 2013 7:42 am
I've assigned a high priority to this ticket.
