I am trying to draw a sample graph using the evaluation version of TeeChart.
I need to draw around 12 line, 12 bar and 1 area chart in a single graph but the evaluation version is allowing me to draw only 4 charts.
Please let me know whether this is possible with the evaluation version or not. A quick response will be appreciated.
Thanks in advance
Limitation with Evaluation Version
Hi SDG,
There's no limitation on the number of series you can add to the evaluation version of TeeChart for Java. Actually the only limitation is the number of series and points your machine's memory can handle.
The only limitation the evaluation version has is an Evaluation watermark.
