I do need to serialize/deserialize chart in xml format.
When I do export, using ChartEditor, I have this exception raised:
java.lang.NullPointerException
at com.steema.teechart.Aspect.getTextSmooth(Aspect.java:225)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:36)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:243)
at java.beans.Statement.invoke(Statement.java:215)
at java.beans.Expression.getValue(Expression.java:98)
at java.beans.DefaultPersistenceDelegate.doProperty(DefaultPersistenceDelegate.java:215)
at java.beans.DefaultPersistenceDelegate.initBean(DefaultPersistenceDelegate.java:251)
at java.beans.DefaultPersistenceDelegate.initialize(DefaultPersistenceDelegate.java:395)
at java.beans.PersistenceDelegate.writeObject(PersistenceDelegate.java:100)
at java.beans.Encoder.writeObject(Encoder.java:54)
at java.beans.XMLEncoder.writeObject(XMLEncoder.java:254)
at java.beans.Encoder.writeExpression(Encoder.java:259)
at java.beans.XMLEncoder.writeExpression(XMLEncoder.java:369)
at java.beans.DefaultPersistenceDelegate.doProperty(DefaultPersistenceDelegate.java:216)
at java.beans.PersistenceDelegate.writeObject(PersistenceDelegate.java:97)
at java.beans.Encoder.writeObject1(Encoder.java:186)
at java.beans.Encoder.cloneStatement(Encoder.java:199)
at java.beans.Encoder.writeStatement(Encoder.java:230)
at java.beans.XMLEncoder.writeStatement(XMLEncoder.java:328)
at java.beans.XMLEncoder.writeObject(XMLEncoder.java:257)
at com.steema.teechart.exports.Exports$TemplateExport.toXML(Exports.java:305)
at com.steema.teechart.exports.Exports$TemplateExport.toXML(Exports.java:248)
at com.steema.teechart.exports.Exports$TemplateExport.toXML(Exports.java:237)
at com.steema.teechart.editors.export.ExportPanel.saveTemplate(ExportPanel.java:512)
at com.steema.teechart.editors.export.ExportPanel.bSave_actionPerformed(ExportPanel.java:477)
at com.steema.teechart.editors.export.ExportEditor_bSave_actionAdapter.actionPerformed(ExportPanel.java:878)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1849)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2169)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:5517)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
at java.awt.Component.processEvent(Component.java:5282)
at java.awt.Container.processEvent(Container.java:1966)
at java.awt.Component.dispatchEventImpl(Component.java:3984)
at java.awt.Container.dispatchEventImpl(Container.java:2024)
at java.awt.Component.dispatchEvent(Component.java:3819)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4212)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3892)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3822)
at java.awt.Container.dispatchEventImpl(Container.java:2010)
at java.awt.Window.dispatchEventImpl(Window.java:1791)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:153)
at java.awt.Dialog$1.run(Dialog.java:535)
at java.awt.Dialog$2.run(Dialog.java:565)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Dialog.java:563)
at java.awt.Component.show(Component.java:1302)
at java.awt.Component.setVisible(Component.java:1255)
at com.steema.teechart.editors.ChartEditor.editChart(ChartEditor.java:107)
at com.steema.teechart.editors.ChartEditor.editChart(ChartEditor.java:102)
at com.altio.controls.chart.demo.TeeChartRadar.backgroundClicked(TeeChartRadar.java:141)
at com.steema.teechart.TChart.fireChartClicked(TChart.java:142)
at com.steema.teechart.TChart.checkBackground(TChart.java:695)
at com.steema.teechart.Chart.mousePressed(Chart.java:1208)
at com.steema.teechart.TChart.processMouseEvent(TChart.java:1347)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3889)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
java.lang.InstantiationException: com.steema.teechart.drawing.StringAlignment
at java.lang.Class.newInstance0(Class.java:335)
at java.lang.Class.newInstance(Class.java:303)
at java.beans.Encoder.getValue(Encoder.java:85)
at java.beans.Encoder.get(Encoder.java:180)
at java.beans.PersistenceDelegate.writeObject(PersistenceDelegate.java:94)
java.lang.RuntimeException: failed to evaluate: <unbound>=Class.new();
at java.beans.Encoder.getValue(Encoder.java:89)
java.lang.NoSuchMethodException: <unbound>=Area.getTreatNulls();
at java.beans.Statement.invoke(Statement.java:236)
at java.beans.DefaultPersistenceDelegate.doProperty(DefaultPersistenceDelegate.java:214)
at java.beans.DefaultPersistenceDelegate.invokeStatement(DefaultPersistenceDelegate.java:239)
at java.beans.java_util_List_PersistenceDelegate.initialize(MetaData.java:247)
at java.beans.PersistenceDelegate.initialize(PersistenceDelegate.java:190)
at java.beans.DefaultPersistenceDelegate.initialize(DefaultPersistenceDelegate.java:393)
Can you please help me and look into this problem, it is quite critical for our application?
Thanks in advance,
Olexiy.
