Pie chart on teechart java v2
Posted: Fri Feb 20, 2009 4:35 pm
by 6921228
I'm trying the evaluation version 2 and when I try to print or write the image the program goes into the dump. I also tried the applet in the folder examples/swing but also when selecting the styles pie the applet freezes.
Thanks for any suggestions.
This is the error
java.lang.NullPointerException
at com.steema.teechart.drawing.Graphics3DAWT.unClip(Unknown Source)
at com.steema.teechart.styles.Series.clipRegionDone(Unknown Source)
at com.steema.teechart.Chart.internalDraw(Unknown Source)
at com.steema.teechart.Chart.paint(Unknown Source)
at com.steema.teechart.exports.ImageExport.image(Unknown Source)
at com.steema.teechart.Chart.image(Unknown Source)
at com.steema.teechart.exports.ImageExportFormat.save(Unknown Source)
Posted: Mon Feb 23, 2009 4:50 pm
by narcis
Hi newsoft,
I'm not able to reproduce the issue here using TeeChart.Features.jar demo nor in a simple example project (see code below). Could you please let us know the exact steps we should follow in the demo or modify code snippet below so that we can reproduce the problem here?
try {
commander1.setChart(tChart1.getChart());
Pie pie1 = new Pie(tChart1.getChart());
pie1.fillSampleValues();
tChart1.getExport().getImage().getJPEG().save("c:\\temp\\piejava.jpg");
} catch (IOException ex) {
Logger.getLogger(DesktopApplication1View.class.getName()).log(Level.SEVERE, null, ex);
Posted: Tue Feb 24, 2009 10:20 am
by 6921228
Hi Narcís,
I use TeeChart.Swing.jar v2 lib evaluation version, this is my example:
package testteechartpie;
import java.awt.Container;
import java.awt.BorderLayout;
import javax.swing.*;
import javax.swing.JButton;
import javax.swing.JPanel;
import com.steema.teechart.Chart;
import com.steema.teechart.Commander;
import com.steema.teechart.styles.Series;
import com.steema.teechart.styles.Bar;
import com.steema.teechart.styles.Pie;
import com.steema.teechart.drawing.Color;
final public class nsTCp extends JPanel {
static TChart chart;
JButton colorButton;
JToolBar oc; // Commander
Container cnt;
JPanel mPane;//,tPane,bPane;
Series ss;
public static void main(final String[] args) {
javax.swing.SwingUtilities.invokeLater(new Runnable() {
public void run() {
try {
UIManager.setLookAndFeel(UIManager.getSystemLookAndFeelClassName());
nsTCp a=new nsTCp();
System.exit(0);
} catch (Exception ex) {
ex.printStackTrace();
public nsTCp() {
super(new BorderLayout());
com.steema.teechart.exports.ImageExport img;
cnt =this;
// ** OK bar.jp is created**
displayChart(1);
try {
chart.getChart().getExport().getImage().getJPEG().save("bar.jpg");
} catch (Exception e) {
e.printStackTrace();
System.err.println(e.toString());
// ** ERROR pie.jpg is empty **
displayChart(2);
try {
chart.getChart().getExport().getImage().getJPEG().save("pie.jpg");
private void displayChart(int tp) {
Chart c;
setChartLayout(1);
if (tp==1) {
c =chart.getChart();
Bar b =new Bar();
b.fillSampleValues(15);
c.addSeries(b);
} else {
Pie b =new Pie();
c.addSeries(b);
chart.setVisible(true);
private void setChartLayout(int tp) {
mPane = new JPanel();
mPane.setLayout(new BorderLayout());
mPane.setBackground(Color.yellow);
cnt.add(mPane,BorderLayout.CENTER);
chart =new com.steema.teechart.TChart();
Commander oc_tmp;
oc_tmp =new Commander(chart.getChart());
oc_tmp.setLabelValues(true);
oc =(Commander)oc_tmp;
if (oc!=null) {
oc.setEnabled(true);
oc.setVisible(true);
mPane.add(oc,BorderLayout.PAGE_START);
mPane.add(chart, BorderLayout.CENTER);
chart.setHeight(cnt.getHeight() - (oc!=null ? oc.getHeight() : 0));
chart.setWidth (cnt.getWidth() );
if (oc!=null) {chart.setLocation(0,oc.getHeight());}
The java version is build 1.6.0_11-b03.
Let me remind you that in the example Examples/Swing/Applet/TChartAppletDemo.htm when I select the pie chart applet hangs.
Thank you for your replay.
Posted: Tue Feb 24, 2009 1:00 pm
by narcis
Hi newsoft,
It's not clear to us which is the TeeChart version you are using. This seems to be the Java Runtime Environment version number. At Steema Software's
version info page you can see the exact releases for each TeeChart version. Below you can find TeeChart for Java v1 and v2 release notes:
http://www.steema.com/files/public/teec ... tJava1.txt
http://www.steema.com/files/public/teec ... tJava2.txt
Your code is very similar to the code snippet I posted. Does it work fine at your end? Could you please modify it so that we can reproduce the problem here?
We will investigate this but works fine here:
http://www.steema.com/products/teechart ... etDemo.htm
Posted: Wed Feb 25, 2009 12:34 pm
by 6921228
Hi Narcís,
the version is not the same, the link that you have specified using the evaluation version 2.0.0.701 while the one I use is the evaluation 2.0.0.771, downloaded from your site. I think this is the problem, can you tell me where to download the TeeChart.Swing.jar 2.0.0.701 version.
Thank you.
Posted: Wed Feb 25, 2009 2:42 pm
by 6921228
I downloaded again from the "private customer downloads" the trial version but it is always the 2.0.0.771.
The site writes:
TeeChart Pro for Java -- Evaluation version
Download:
Latest Binary version: 24th Nov 2008, Build 2.0.0.701.
Installer File hash (reg. ver): MD5: 11C0AE040F9EC5493F6829CE124C6CF8
(eval. ver): MD5: 40D6317232DE7644CA20BB34D00AD905
Click here to download TeeChart for Java Evaluation version 2
(compiled binary classes, demos and documentation) 17MB (updated 22nd Jan 09)
but it's false, the version is'nt 2.0.0.701, the download link is:
http://www.teechart.net/files/java/publ ... uation.zip.
Posted: Wed Feb 25, 2009 3:04 pm
by narcis
Hi newsoft,
Thanks for the information. This is possibly because the Evaluation version could be built later and hence small difference in build number. However, could you please check if the code snippet I posted works fine for you or can you modify it so that we can reproduce the problem here?
Posted: Wed Feb 25, 2009 3:53 pm
by 6921228
Hi Narcís,
Sorry if I do not do other tests, but in the version I downloaded the applet hangs when you select the pie chart, it is enough that you download, unzip and run the demo applet in the folder Examples/Swing/Applet, you'll see that it crashes. Basically if you try the version 2.0.0.771 to 2.0.0.701 place you'll see that the problem occurs. You can also try to
http://www.studiomuscella.it/teechart/T ... etDemo.htm I have done from different computers and the problem still occurs.
Thank you and sorry for my English, I am using a translator and my little knowledge of the language.
Posted: Wed Feb 25, 2009 5:01 pm
by 6921228
Hi Narcís,
I found the old version, and without changing anything in the source everything works perfectly, this is proof that there is a problem on the pie charts in the new version (2.0.0.771).
Thanks for your support.
Posted: Fri Feb 27, 2009 8:03 am
by narcis
Hi newsoft,
I can't reproduce this. Neither using the demo you posted nor using our current source code so you may expect the issue being solved for the next maintenance release. You could also try checking if there's any Java upgrade that can be applied to your environment.
