Lines (Fastlines) disappear when window is resized
Posted: Fri Jan 16, 2009 12:12 pm
by 7665917
We are working on a Java real-time application using TChart.
At the moment we are facing a problem when we are changing the width of a window including a TCHart component. In this case it happens that lines disappear.
This error occurs since we changed from Horizontal to Fast lines.
It seems to be that the algorithm of redrawing the TChart doesn't work properly for Fastlines (It doesn't draw all lines for some sizes)
See:
http://www.opus.ch/staff/christian/stee ... window.doc
Posted: Fri Jan 16, 2009 2:19 pm
by narcis
Hi Chh,
Looking at your document it's unclear to us how should we reproduce the issue here. Are you using FastLine series setting XValues.Order=None or ar you using HorizLine series? It would be very helpful if you could send us a simple example project or a code snippet we can run "as-is" to reproduce the problem here and let us know the exact TeeChart version you are using?
