Page 1 of 2
Line chart - x-axis labels
Posted: Mon Jul 28, 2008 7:40 pm
by 7667591
I use FastLine for creating line charts.
Suppose I have to add (1,2,3,4,5, [Missing]) on the X-axis, then how would I do that ? I normally use add(double, double), but now I have a special case wherein I have to add a String value to the X-axis along with some double values. I tried using add(double, String) along with add(double, double). But I am getting exceptions when I call the former one. So is it like, we can not have two data types on the same Axis ? Or am I calling some wrong API ?
Varun
Posted: Tue Jul 29, 2008 11:15 am
by narcis
Hi Varun,
This is a bug (TJ71013286). Calling add method with a string parameter raises an exception. I've added the issue to the defect list to be fixed ASAP.
In the meantime you can use custom axis labels as shown in the Axes\Labels\Custom Labels II example at TeeChart.Features.jar.
Posted: Tue Jul 29, 2008 11:49 am
by narcis
Hi Varun,
As an update, I've just fixed this issue for the next TeeChart for Java release. When it comes out you'll be able to do this:
Random y = new Random();
for (int i=0; i<5; i++) {
line1.add(i,y.nextDouble(), String.valueOf(i));
line1.add("Missing");
I recommend you to be aware at this forum or subscribe to our
RSS news feed for new release announcements.
Posted: Tue Jul 29, 2008 5:11 pm
by 7667591
I do not know whether you have understood my question or not. Maybe we are talking about the same thing. I just want to confirm my view points.
I have an X-axis and a Y-Axis.
X- axis - represents integer or continuous variable. (1,2,3,4,...)
Y -axis - represents a double variable.
So I use line.add(double, double) to add points to a line series.
But in some special cases, I have to represent a null value on the x-axis for the same series. So my x- axis labels would look like(1,2,3,4,....,[Missing]).
So when I see a [Missing] in my data, I try to use line.add(double, "[Missing]") instead of line.add(double, double). This time I am getting some exceptions which I have mentioned in my first mail. I suppose that, two different calls to add points to the same line series causes these exceptions. Am I doing something wrong here ? Or is it a special case for me ?
Varun
Posted: Wed Jul 30, 2008 7:35 am
by narcis
Hi Varun,
Thanks for the information. I think we are speaking about the same issue. I did some tests with what you reported and I found that any add method override that uses a string parameter caused an exception. That's what I fixed yesterday and the bug fix will be included in the next maintenance release.
Can you confirm that what's causing exceptions at your end is using add method with a string?
Posted: Wed Jul 30, 2008 2:50 pm
by 7667591
Yes when I add(double, String), I am getting the exceptions. Where I can download the maintenance releases ? I am using may 22nd build now.
Varun
Posted: Wed Jul 30, 2008 2:56 pm
by narcis
Hi Varun,
The version you are using is the last publically available. When a new maintenance release is posted it will be announced in this forum. You may also be interested in subscribing to our
RSS news feed for automatic announcements.
In the meantime, I'll send you StringList.java with the fix to this issue, you can backup and replace current version for the new one and compile your projects from TeeChart's sources.
Posted: Thu Jul 31, 2008 4:32 pm
by 7667591
Please send StringList.java to my email id - varun dot balakrishnan at amd dot com
Varun
Posted: Fri Aug 01, 2008 7:19 am
by narcis
Hi Varun,
Sure, just sent it.
Posted: Fri Aug 01, 2008 7:43 pm
by 7667591
Thanks for sending the file. It could eliminate the exception but it did not add the point to the line series. I do not see the added point in the chart.
The code below explains what I was trying to do,
try {
Double xAxisPoint = Double.parseDouble(xLabelItem);
series[count].add(xAxisPoint, yData.doubleValue());
} catch (NumberFormatException ne) {
series[count].add(yData.doubleValue(),xLabelItem);
I have 3 xvalues (1,15 and [Missing]) and corresponding yvalues. Chart displays only 1 and 15.
Varun
Posted: Thu Aug 07, 2008 4:30 pm
by 7667591
Why there is no response for my question ? Or you think that my requirements does not make any sense ??
Varun
Posted: Fri Aug 08, 2008 11:10 am
by Marc
Hello Varun,
Sorry for the delay. Personnel changes for holidays caused us to need to re-tread the steps on this issue. Re-checking this, rolling back to before the fix you're testing doesn't give the same results as discussed in this thread.
The following uses a FastLine, adds Labels and adds a zero value for the last 'missing' value:
com.steema.teechart.styles.FastLine line1 = new com.steema.teechart.styles.FastLine(tChart.getChart());
java.util.Random y = new java.util.Random();
line1.add(i,y.nextDouble(), "val " + String.valueOf(i));
If you wish the last value to add the Label but no value to be plotted then you could do the following:
if (i < 4)
line1.add(i,y.nextDouble(), "missing");
line1.setNull( i );
line1.setIgnoreNulls( false );
The value could exist as a null between other values, eg. changing the loop to:
for (int i=0; i<10; i++) {
if (i == 4)
line1.setNull( i );
Please let us know if that doesn't resolve the question in hand.
Posted: Fri Aug 08, 2008 9:29 pm
by 7667591
No it does not solve my issue.
1)
Why we need to add "missing" always at the end or at the beginning.
I noticed that when I try to add "missing" in between some values then it is not showing up in the chart.
2)
If you run the code shown below then you will see a gap between 2 and 4.
Why is it like this? I do not want to see breaks in between my x axis label items. Is there any way I could solve this issue/feature/bug ?.
3) series.add(ArrayList xvalues, ArrayList yvalues) does not work.
If you see the source code, it returns null arrays.
import javax.swing.JFrame;
import javax.swing.JPanel;
import com.steema.teechart.styles.FastLine;
public class TestTeeChart {
* @param args
JFrame frame = new JFrame();
JPanel panel = new JPanel();
panel.setSize(600, 600);
TChart chart = new TChart();
panel.add(chart);
FastLine fastLine = new FastLine(chart.getChart());
for (int i = 0; i < 10; i++) {
if (i != 3)
fastLine.add(i, i * i, "" + i);
frame.add(panel);
frame.setSize(600, 600);
frame.setVisible(true);
4) I am new to charting domain so please bear with me if I am conveying something really stupid.
As per my initial understanding, A line chart or trend chart is ;-
A graph that uses points connected by lines to show how something changes in value (as time goes by, or as something else happens).
We need to consider x-axis as a categorical axis in the case of a line chart. So we need to have equal spacing between x axis labels.
eg-:
http://pubs.logicalexpressions.com/pub0 ... asp?ID=190
I may not have understood TChart API's very well. So if you could clear all my doubts then it would be very helpful.
Varun
Posted: Mon Aug 11, 2008 12:00 pm
by Marc
Hello Varun,
Re. when I try to add "missing" in between some values then it is not showing up in the chart.
The code from my last post would be an example of that. The Label shows correctly here:
if (i == 4)
line1.setNull( i );
It may be that there is no physical space on the Axis if you have many values, though with the example above for a standard dimensioned Chart I wouldn't expect a problem. To improve fit though, when there are many labels, you can change the Angle of them:
eg.
tChart.getAxes().getBottom().getLabels().setAngle(90);
2. Gap between 2 and 4.
If you add Labels with your data TeeChart assumes you are overriding default control of the Labels and follows the instruction of doing nothing (in this example) at 3.
Modify you loop to treat those Labels that the loop omits.
if (i != 3)
line1.add(i, i * i, " " + i);
line1.add(i, 0.0, " " + i);
line1.setNull( i );
or (simpler maybe)
if (i != 3)
line1.add(i, i * i, " " + i,Color.BLUE);
line1.add(i, i, " " + i, Color.TRANSPARENT);
Re. 3) series.add(ArrayList xvalues, ArrayList yvalues) does not work.
Yes, that fails, we have fixed it now for inclusion in the next update (imminent), and included an overload for double[],double[] that might be more practical for some developers. Aplogies for the inconvenience caused.
Re 4.
Your description seems coherent to me. With regard to null points we have received multiple views from different developers on how they would like to see them plotted. TeeChart attempts to offer more than one option in its API. Once coded the decision on that option becomes fixed for that application (if requiring to be fixed). The next update of TeeChart for Java, currently being developed, includes a type called TreatNulls to offer several predefined options for dealing with null values.
Posted: Mon Aug 11, 2008 8:49 pm
by 7667591
Thanks for your reply. I think you have not completely understood my question number 2. Even if I follow your instructions, I would get a 3 in between 2 and 4. I do not want to display 3 and its axis point in the chart.
The x-axis should be like 1 2 4 5 6 7 8 9. If you plot a line chart in MS Excel then you would get a better understanding of my issue.
http://picasaweb.google.com/cbvarun/Ste ... 5609702322
Varun
