Small Axis values not displayed or chopped
Marius
Post by Marius » Wed Jul 16, 2008 10:49 am
I have a probably very trivial question: I have an axis scale which could require some very small values (E-8'ish), but when I plot it the values stop being differentiated at around E-3. When setting the xaxis.getIncrement to something very small, nothing happens. If I do not set it at all, no values (or only one) are displayed on the axis.
So, any thoughts? I am including a very small dummyproject so you can tell me what I am not getting right :)
import javax.swing.JFrame;
import javax.swing.JPanel;
import com.steema.teechart.TChart;
import com.steema.teechart.styles.Points;
public class SmallValues extends JFrame
    JPanel dmb = new JPanel();
    TChart myChart = new TChart();
    double[] x = new double[] {0.00001,0.00002,0.00005};
    double[] y = new double[] {1,2,3};
    public static void main(String[] args)
        new SmallValues().setVisible(true);
    public SmallValues()
        dmb.add(myChart);
        add(dmb);
        setSize(400,300);
        Points p = new Points(myChart.getChart().chart);
        p.add(y);
        p.getXValues().value = x;
        myChart.getAxes().getBottom().setIncrement(0.000001);
Thanks in advance
Marius
Post by Narcís » Wed Jul 16, 2008 11:07 am
Hi Marius,
Have you tried setting labels' ValueFormat?
chart1.getAxes().getBottom().getLabels().setValueFormat("#.##########");
Marius
:D
Post by Marius » Wed Jul 16, 2008 11:17 am
That of course did the trick, and I thank you for the swift and precise answer!
M
Post by Narcís » Wed Jul 16, 2008 11:21 am
Hi Marius,
You're very welcome! I'm glad to hear that helped.
Marius
Post by Marius » Wed Jul 16, 2008 12:53 pm
One follow-up; can the valueformat be set to Exponential somehow? I tried setExponent(true) but with no luck. Or do I need to format the values before I include them on the axis(/ie before I add them onto the series)?
M
Post by Narcís » Wed Jul 16, 2008 1:23 pm
Hi Marius,
Yes, you can do this:
        chart1.getAxes().getBottom().getLabels().setValueFormat("0.00E0");
