Problem
Posted: Fri Jan 18, 2008 2:14 pm
Hi! I am experiencing a problem. I'm developing an apPplet that uses the TeeChart Pro v7 for Java. In this applet, there is a 3D Pie, which has a focus tool. But when I explode a pie's slice this event doesn't work right. The focus of the slices is painted and imediatelly unpainted. I did an example of the problem to you can see. Is it possible a pie that has focus and exploded at same time? I'm waiting an answer! Thank's Roberto
http://www.q10.com.br/temp/teste_teechart.zip
