Hi:
We are trying to do the following programmatically. How can we access these parameters? Thanks.
From Editor panel -
1. Go to edit and select General under chart
2. Select zoom
3. set border to visible, width 0 and select color as blue
4. Now select pattern and set visible and select lightblue from swatches
Can we set these parameters?
best regards,
Programmatic control of Editor Components
Hi cdn,
Yes, you can do something like this:
tChart.getZoom().getPen().setVisible(true);
tChart.getZoom().getPen().setWidth(0);
tChart.getZoom().getPen().setColor(Color.BLUE);
tChart.getZoom().getBrush().setVisible(true);
tChart.getZoom().getBrush().setColor(Color.CYAN);
Hi:
Associated question -
How can we disable orthogonal property, programmatically? We are using the following snippet to set the property to "false". But, when we check the editor it always shows it as "checked".
Any input is welcome. Thanks.
best regards,
Aspect asp = new Aspect(tChart2.getChart());
asp.setOrthogonal(false);
best regards,
