Cannot compile source /Examples/Swing /*.java
Posted: Thu Dec 07, 2006 3:09 pm
Dear Steema people,
I have been using TeeChart already for a number of years now within the Delphi environment. I also programme in Java and I want to see whether I can use TeeChart with Java too. A while ago I therefore downloaded the evaluation version of TeeChart For Java Build 1.0.1.818, to be precise on 10-Nov-2006.
Today I tried to run a few examples. Unfortunately, my first attempt failed miserably. I added the files Application1.java and Frame1.java to a module and tried to compile. My problems:
1. the import com.sun.java.swing.plaf.gtk.* could not be resolved - maybe because I'm running Windows???
2. class ChartPaintEvent which is referenced in the argument list of methods afterChartPaint and tChart2_afterDrawPerformed cannot be resolved.
Fortunately, I was able to run the AWT example. All the same, I would like to get the Swing example working too. What can I do to achieve this? TIA
Kind regards,
Dobedani
Wageningen
The Netherlands
Kind regards,
Dobedani
Wageningen
The Netherlands
