custom tooltip
Mulderone
custom tooltip
Post by Mulderone » Tue Nov 22, 2011 9:40 am
I'm using a line series graph with pointer.
How to create custom tooltip when i click on pointer ?
Thanks a lot for your answer.
Mulderone
Re: custom tooltip
Post by Mulderone » Tue Nov 22, 2011 11:00 am
I also want to custom the display of label to add an icon to represent a level for each y value
Re: custom tooltip
Post by Narcís » Tue Nov 22, 2011 11:01 am
Hi Mulderone,
You should use a MarksTip tool as in the Tools -> Mark Tips examples at TeeChart.Features.jar demo.
Hope this helps!
Mulderone
Re: custom tooltip
Post by Mulderone » Tue Nov 22, 2011 12:25 pm
i look at the code and test it but it's not precise when you touch the screen.
It's possible to add a listener on the SeriePoint or get the nearest SeriePointer for an X,Y coordinate ?
I understand that the android version share the same code as Java library but using mouse on PC is most precise, which is not the case on Android device.
I just want to touch a single point on the line series and draw a custom toast nearest the point.
Is it possible or not ?
Re: custom tooltip
Post by Narcís » Tue Nov 22, 2011 12:40 pm
Hi Mulderone,
Yes, you could use series' click event, its clicked method in chart mouse events or the NearestPoint tool.
Mulderone
Re: custom tooltip
Post by Mulderone » Tue Nov 22, 2011 1:26 pm
Could you be more precise ?
the series accept only 2 listeners, i'm using the the serieMouseListener but i 'have a nullPointer exception when i touch the graph and i can't find the nearestPoint method
Could you help me ?
final Series series = Series.createNewSeries(this.getChart(), Line.class,
					null);
			series.getXValues().setDateTime(true);
			 * Configuration graphique des points de la série
			final SeriesPointer seriesPointer = ((CustomPoint) series).getPointer();
			seriesPointer.setVisible(true);
			seriesPointer.setVertSize(6);
			seriesPointer.setHorizSize(6);
			seriesPointer.setColor(series.getColor());
			seriesPointer.getPen().setColor(Color.WHITE);
			seriesPointer.getPen().setVisible(true);
			seriesPointer.getPen().setWidth(3);
			seriesPointer.setStyle(PointerStyle.CIRCLE);
			 * Configuration graphique des tooltips de chaque point
			final MarksTip marksTip = new MarksTip(
					this.getChart());
			series.addSeriesMouseListener(new SeriesMouseAdapter() {
				public void seriesClicked(SeriesMouseEvent e) {
					marksTip.setMouseDelay(0);
					marksTip.setSeries(series);
					Toast t;
					t = Toast.makeText(activity, marksTip.getSeries()
							.getValueMarkText(e.getValueIndex()),
							Toast.LENGTH_SHORT);
					t.show();
the NullPointerException stackTrace
11-22 14:26:13.745: E/AndroidRuntime(2049): java.lang.NullPointerException
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.styles.Custom.checkPointInLine(Custom.java:425)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.styles.Custom.clicked(Custom.java:510)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.styles.Series.clicked(Series.java:3130)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.tools.MarksTip.mouseEvent(MarksTip.java:222)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.Chart.broadcastMouseEvent(Chart.java:938)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.Chart.broadcastMouseEvent(Chart.java:928)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.Chart.mouseMoved(Chart.java:1313)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.TChart.processMouseMotionEvent(TChart.java:971)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.steema.teechart.TChart.onTouch(TChart.java:1137)
11-22 14:26:13.745: E/AndroidRuntime(2049): at android.view.View.dispatchTouchEvent(View.java:3762)
11-22 14:26:13.745: E/AndroidRuntime(2049): at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:936)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.android.internal.policy.impl.PhoneWindow$DecorView.superDispatchTouchEvent(PhoneWindow.java:1716)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.android.internal.policy.impl.PhoneWindow.superDispatchTouchEvent(PhoneWindow.java:1114)
11-22 14:26:13.745: E/AndroidRuntime(2049): at android.app.Activity.dispatchTouchEvent(Activity.java:2086)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.android.internal.policy.impl.PhoneWindow$DecorView.dispatchTouchEvent(PhoneWindow.java:1700)
11-22 14:26:13.745: E/AndroidRuntime(2049): at android.view.ViewRoot.handleMessage(ViewRoot.java:1785)
11-22 14:26:13.745: E/AndroidRuntime(2049): at android.os.Handler.dispatchMessage(Handler.java:99)
11-22 14:26:13.745: E/AndroidRuntime(2049): at android.os.Looper.loop(Looper.java:123)
11-22 14:26:13.745: E/AndroidRuntime(2049): at android.app.ActivityThread.main(ActivityThread.java:4627)
11-22 14:26:13.745: E/AndroidRuntime(2049): at java.lang.reflect.Method.invokeNative(Native Method)
11-22 14:26:13.745: E/AndroidRuntime(2049): at java.lang.reflect.Method.invoke(Method.java:521)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:868)
11-22 14:26:13.745: E/AndroidRuntime(2049): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:626)
11-22 14:26:13.745: E/AndroidRuntime(2049): at dalvik.system.NativeStart.main(Native Method)
Re: custom tooltip
Post by Yeray » Thu Nov 24, 2011 3:03 pm
Hello Mulderone,
I'm not getting the error you are with that code but I see the MarksTip has an strange response. It has to be revised.
In the meanwhile, the following code seems to work better, could you please give it a try?
	private static com.steema.teechart.tools.Annotation annot1;
	com.steema.teechart.styles.Line lineSeries;
	private void initializeChart() {
		tChart1.getLegend().setVisible(false);
		lineSeries = new com.steema.teechart.styles.Line(tChart1.getChart());
		lineSeries.getPointer().setVisible(true);
		lineSeries.fillSampleValues(10);
		annot1 = new com.steema.teechart.tools.Annotation(tChart1.getChart());
		annot1.setActive(false);
		lineSeries.addSeriesMouseListener(new SeriesMouseListener() {
			@Override
			public void seriesExited(SeriesMouseEvent e) {}
			@Override
			public void seriesEntered(SeriesMouseEvent e) {}
			@Override
				for (int valueIndex=0; valueIndex<lineSeries.getCount(); valueIndex++) {
					if (lineSeries.clickedPointer(lineSeries.calcXPos(valueIndex), lineSeries.calcYPos(valueIndex), e.getPoint().x, e.getPoint().y)) {
						annot1.setText(String.valueOf(lineSeries.getYValues().getValue(valueIndex)));
						annot1.getShape().setCustomPosition(true);
						annot1.setLeft(e.getPoint().x);
						annot1.setTop(e.getPoint().y - 20);
						annot1.setActive(true);
Mulderone
Re: custom tooltip
Post by Mulderone » Mon Nov 28, 2011 3:33 pm
thanks for your help.
I've found a solution : a SerieMouseListener and i'm using a Toast object with a custom inner view.
I don't pop-up the toast near the point but the look&feel is ok
