Unicode problem
leihj
Unicode problem
Post by leihj » Fri Jul 15, 2011 9:21 am
We develop our project in WAS(WebSphere)6.0 ,but the chinese char in the chart is the messy code. The environment of server is Ubuntu9+WAS6. How should we solve this problem?
Thanks!
Candy
Re: Unicode problem
Post by Yeray » Tue Jul 19, 2011 11:39 am
Hello Candy,
The following code seems to work fine for me here.
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Display;
import org.eclipse.swt.widgets.Shell;
import com.steema.teechart.TChart;
public class Test {
	static TChart tChart1;
    public static void main(String [] args){
        final Display display = new Display();
        Shell shell = new Shell(display);
        shell.setLayout(new FillLayout());
        shell.setSize(600,400);
        createChart(shell);
        initializechart();
        shell.open();
        while (!shell.isDisposed()) {
        	if (!display.readAndDispatch()) {
        		display.sleep();
        display.dispose();
	private static void createChart(Shell tmpShell) {
		tChart1 = new TChart(tmpShell, 0);
	private static void initializechart() {
		com.steema.teechart.styles.Bar bar1 = new com.steema.teechart.styles.Bar(tChart1.getChart());
		bar1.add(20, "玩具");
		bar1.add(40, "椅子");
		bar1.add(30, "灯");
Could you please send us a simple example project we can run as-is to reproduce the problem here?
