bug on legend position Top with a long legend title
Posted: Thu Feb 17, 2011 11:06 pm
by 7667590
Bug 1)
I don't have a problem with a legend whose position is either Left or Right. When I change the legend position to either Top or Bottom with a long legend title, the width of the legend bounds isn't correctly rendered. In other words, the long legend title can't fit into the legend whose position is either Top or Bottom. The following is a sample code of what i am talking about. Is there a way to make the legend width suitable with the legend title when the position is Top or Bottom, just like when the position is either Right or Left?
Bug 2)
I noticed that the icon for the legend item gets smaller when the position is Top/Bottom when compared to the position of Left/Right? Is there a way to have a same size of the icon for the legend item when its position is either Top or Bottom? You will see the different size of the icon within the legend when you change the position from Left/Right to Top/Bottom.
		JFrame frame = new JFrame();
		JPanel panel = new JPanel();
		panel.setSize(600, 600);
		TChart chart = new TChart();
		panel.add(chart);
		Bar b = new Bar(chart.getChart());
		b.add(0, 10, Color.BLACK);
		b.add(1, 20, Color.BLACK);
		b.add(2, 30, Color.BLACK);
		b.setTitle("first series");
		Bar b1 = new Bar(chart.getChart());
		b1.add(0, 10, Color.RED);
		b1.add(1, 10, Color.RED);
		b1.add(2, 10, Color.RED);
		b1.setMultiBar(MultiBars.STACKED);
		b1.setTitle("second series");
		String title = "here is a quite long legend title to see if this can fit into legend top";
		chart.getLegend().getTitle().setText(title);
		chart.getLegend().setAlignment(LegendAlignment.TOP);
//		chart.getLegend().setAlignment(LegendAlignment.BOTTOM);
		frame.add(panel);
		frame.setSize(600, 600);
		frame.setVisible(true);
Re: bug on legend position Top with a long legend title
Posted: Mon Feb 21, 2011 12:16 pm
Hi Jonathan,
I can see the Bug #1 you reported so I've added it to the defect list to be fixed in future releases (TJ71015403).
Regarding the Bug #2, I don't see any difference between default alignment (right) and top alignment. Here is my result with NetBeans 6.9.1:
Posted: Mon Feb 21, 2011 3:44 pm
by 7667590
1) Is there any workaround I can do now for the Bug #1 ?
2) The size of blue and orange images got a bit smaller when the position is top/bottom, when compared to left/right. I can even see the a little difference on the image you posted.
Posted: Mon Feb 21, 2011 5:56 pm
Hi Jonathan,
Jonathan wrote:1) Is there any workaround I can do now for the Bug #1 ?
You could use the LegendResolver to manually modify the legend rect:
        tChart1.setLegendResolver(new LegendResolver() {
            @Override
            public Rectangle getBounds(Legend legend, Rectangle rectangle) {
                return new Rectangle(200,20,400,legend.getHeight());
            @Override
            public LegendItemCoordinates getItemCoordinates(Legend legend, LegendItemCoordinates coordinates) {
                return coordinates;
            @Override
            public String getItemText(Legend legend, LegendStyle legendStyle, int index, String text) {
                return text;
Jonathan wrote:2) The size of blue and orange images got a bit smaller when the position is top/bottom, when compared to left/right. I can even see the a little difference on the image you posted.
You are right. I can see a difference of about two pixels. I've added it to the defect list to be fixed in future releases (TJ71015407).
Posted: Wed Feb 23, 2011 11:23 pm
by 7667590
Thanks for your answers. However, I found 2 problems on the temp solution you provided for the Bug #1.
Problem1) I can't set a hard code of '400' for the legend width because the legend title can vary. There should be a way to convert the legend string title to pixel.
Problem 2) I can't set a hard code of '200' for the legend x coordinates because the legend won't be in center and because the legend would be cropped off. (ditto: y coordinate) There should be a way to calculate x and y into right positions.
Posted: Fri Feb 25, 2011 5:20 pm
Hi Jonathan,
You can always the code suggested with textWidth function to calculate the Legend title width. For example this works fine for me:
                int lwidth = Utils.round(tChart1.getGraphics3D().textWidth(tChart1.getLegend().getTitle().getText())) + 10;
                int leftPos = (tChart1.getWidth()/2) - (lwidth/2);
                return new Rectangle(leftPos,legend.getTop(),lwidth,legend.getHeight());
