Hi All,
Any plans to come-up with features like google finance chart has (Visit - http://www.google.com/finance?q=INDEXDJ ... SDAQ:.IXIC)?
Best,
Veeranna Ronad.
Features of Google Finance Charts
Re: Features of Google Finance Charts
Hi Veeranna,
This is already possible using existing TeeChart features as explained in those threads:
http://www.teechart.net/support/viewtop ... 80&p=41366
http://www.teechart.net/support/viewtop ... 840#p29840
Those are not TeeChart for Java threads but the same applies to the Java version. Moreover, the interpolating example is also available in TeeChart.Features.jar demo, at Chart Styles -> Standard -> Line (Strip) -> Interpolating lines.
Hope this helps!
Hope this helps!
Hi Narcis,
Thanks for the solution. But I could not convert the sample into Java.
colorband1.StartLine.DragLine += new EventHandler(ColorBand_DragLine);
colorband1.EndLine.DragLine += new EventHandler(ColorBand_DragLine);
and
void ColorBand_DragLine(object sender, EventArgs e)
tChart1.Axes.Bottom.SetMinMax(colorband1.Start, colorband1.End);
Kindly advice me.
Best,
Veeranna Ronad.
and
Kindly advice me.
Best,
Veeranna Ronad.
Hi Veeranna,
It seems ColorBand's dragging is not working. I have added the defect to the bug list (TJ71014623) to be fixed. I would expect code below to work.
Line line1 = new Line(tChart1.getChart());
line1.fillSampleValues();
ColorBand colorBand1 = new ColorBand(tChart1.getChart());
colorBand1.setAxis(tChart1.getAxes().getBottom());
colorBand1.setStart(5);
colorBand1.setEnd(15);
colorBand1.getStartLine().setAllowDrag(true);
colorBand1.getEndLine().setAllowDrag(true);
colorBand1.addMouseMotionListener( new MouseMotionListener() {
public void mouseDragged(MouseEvent e) {
tChart1.getHeader().setText(Double.toString(((ColorBand)e.getSource()).getStart()));
public void mouseMoved(MouseEvent e) {
//throw new UnsupportedOperationException("Not supported yet.");
