1. I'd like markers are not blocked each other
2. I'd like values of markers is double type( not int ) example : post 25% => post 25,3%
Dmitry
Small problems
Re: Small problems
Hi Dmitry,
However, I've checked this doesn't work and added the issue (TJ71014544) to the defect list to be fixed. In the meantime the only solution I can think of is formatting manually marks text using the OnGetSeriesMark event as shown in tutorial 6. Tutorials are available at TeeChart's "Docs" folder.
Hope this helps!
You can avoid marks overlapping as shown here. This is a TeeChart for .NET thread but the same applies to TeeChart for Java.1. I'd like markers are not blocked each other
You should be able to set that using PercentFormat:2. I'd like values of markers is double type( not int ) example : post 25% => post 25,3%
Points points1 = new Points(tChart1.getChart());
points1.fillSampleValues();
points1.getMarks().setVisible(true);
points1.getMarks().setStyle(MarksStyle.LABELPERCENT);
points1.setPercentFormat("##0.00 '%'");
Hope this helps!
Re: Small problems
Do you plane add decision overlap problem next release?
Re: Small problems
Hi Dmitry,
I forgot to tell you that you can try using AutoMarkPosition property:
pie1.setAutoMarkPosition(true);
