Small bug in Linux
Posted: Sat Sep 05, 2009 5:14 pm
by 15354003
Re: Small bug in Linux
Posted: Mon Sep 07, 2009 8:15 am
by narcis
Hi Dmitry,
Does this only happen in Linux machines? Have you been able to consistently reproduce this in different computers? With which TeeChart, Java Runtime Environment, development environment and Linux versions occurs?
Posted: Mon Sep 07, 2009 10:24 am
by 15354003
Linux linux19 2.6.25.20-0.5-pae #1 SMP 2009-08-14 01:48:11 +0200 i686 i686 i386 GNU/Linux
OpenSuse 11.0
java version "1.6.0_15"
Java(TM) SE Runtime Environment (build 1.6.0_15-b03)
Java HotSpot(TM) Client VM (build 14.1-b02, mixed mode)
version TeeChart?
TeeChart for Java Build 2.0.0.801 (SWT)
Posted: Mon Sep 07, 2009 10:29 am
by narcis
Hi Dmitry,
Thanks for the info. I forgot to ask you how axes titles text is being added.
Posted: Tue Sep 08, 2009 1:36 pm
by 15354003
And I forgot to say you that strange symbol appear in other title ( chart.getChart().getTitle().setText("Disk pool usage");)
I set title so
chart.getAxes().getLeft().getTitle().setText("% Utilization");
Just do it
Posted: Wed Sep 16, 2009 2:18 pm
by Marc
Your code doesn't provoke the error when tested on Windows. We'll run the test on Linux too. In the meantime, your image shows Chart headers 'BACKUP - ALL' and 'ARCHIVE - ALL'. Those titles don't display the problem; how are those titles set that differs from the problem you find via the code 'chart.getChart().getTitle().setText("Disk pool usage");' ? Are you using a different code line?
With thanks.
Posted: Fri Sep 25, 2009 7:51 am
by 15354003
Strange symbols appear again but on Windows System
SWT version is version 3.550
Posted: Fri Sep 25, 2009 8:46 am
by narcis
Hi Dmitry,
We can not reproduce this in Windows and Swing project with Netbeans in Linux. We are also testing SWT in Eclipse and Linux.
BTW: Do you use any specific code for setting those strings?
Posted: Fri Sep 25, 2009 11:21 am
by 15354003
Attention.
I changed swt library to new 3.550 and strange symbols appeared at once.
Posted: Fri Sep 25, 2009 2:42 pm
by Marc
We've installed swt 3.550 and repeated tests. We're not seeing the error here. We may have missed something, are you able to send us a small sample project that reproduces the error? The error appears as if an extra character is adding itself to the line at some stage, a new-line or carriage return for example.
With thanks.
Posted: Mon Sep 28, 2009 1:18 pm
by 15354003
I started your example from source. Strange symbol is too.
swt 3.5
Posted: Mon Sep 28, 2009 3:08 pm
by Marc
If you run the TeeChart examples from the compiled swt example folder, do you see the same error?
Posted: Mon Sep 28, 2009 3:24 pm
by 15354003
I used your source code and compiled with new swt.
If run compiled swt example(TeeChart.SWT.Features.jar) result is normal without strange symbols
