I was trying to find a way to associate an object with a point in Chart (Line series), because I need to be able to display specific information in the tool tip on mouse hover or alternatively do some specific action on point double click. I tried using the returned value index from the add method, but it does not make sense, because the initial data is not sorted, so any kept index, can be overwritten when the chart rearranges its internal data. Am I missing some obvious way to do this?
Plamen
Associating object with chart point/finding specific chart p
Re: Associating object with chart point/finding specific chart p
Hi Plamen,
You can to use the MarkTextResolver or seriesClicked events provided to change the behaviour according to your needs:
Points point1 = new Points(tChart1.getChart());
point1.fillSampleValues();
point1.addSeriesMouseListener(new SeriesMouseAdapter() {
@Override
public void seriesClicked(SeriesMouseEvent e) {
point1.setMarkTextResolver(new MarkTextResolver() {
@Override
public String getMarkText(int valueIndex, String markText) {
return markText;
thanks for your quick answer, but I am afraid I might have not been clear enough specifying my question.
Suppose I have number of objects, O1 through On.
I want to plot one of their properties vs another, and I also want to be able, when user hovers over a point to retrieve the original object O whose properties this point reflects, and probably to display third property. For example if my object has field members:
double x;
double y;
String name;
I want to be able to retrieve the object whose x and y coordinates this point represents and display name property when the mouse is over this chart point.
I thought that using method add(x,y,text) will do, but it does not work as I expected.
regards,
double x;
double y;
String name;
regards,
If I understand you correctly, you have something like this:
And you want the MaksTip tool to show the name property, not the label.
In that case, you could use mouseMove event to find the object that is represented under the mouse, if any, and store it in a global variable (ie objectUnderMouse). Then, you can use the object stored in this global property, if any, at the MarksTip tool getText event as follows:
final ArrayList<MyObject> myObjectsList = new ArrayList<MyObject>();
for (int i=0; i<10; i++) {
myObjectsList.add(new MyObject());
myObjectsList.get(i).label = "Label " + i;
myObjectsList.get(i).name = "Name " + i;
myObjectsList.get(i).x = i + 1;
myObjectsList.get(i).y = i * 2;
final Points point1 = new Points(tChart1.getChart());
for (int i=0; i<myObjectsList.size(); i++) {
point1.add(myObjectsList.get(i).x, myObjectsList.get(i).y, myObjectsList.get(i).label);
point1.getMarks().setVisible(true);
MarksTip marksTip1 = new MarksTip(tChart1.getChart());
tChart1.getAxes().getBottom().getLabels().setStyle(AxisLabelStyle.VALUE);
tChart1.addMouseMoveListener(new MouseMoveListener() {
@Override
public void mouseMove(MouseEvent arg0) {
int tmpIndex = -1;
for (int i = 0; i < point1.getCount(); i++) {
tmpIndex = point1.clicked(arg0.x, arg0.y);
if (tmpIndex > -1) {
objectUnderMouse = null;
for (int j = 0; i < myObjectsList.size(); j++) {
if (point1.getXValues().getValue(tmpIndex) == myObjectsList
.get(j).x) {
objectUnderMouse = myObjectsList.get(j);
break;
break;
marksTip1.setToolTipResolver(new TextResolver() {
@Override
public String getText(Object sender, String text) {
if (objectUnderMouse != null)
return objectUnderMouse.name;
return text;
Thanks Yeray,
I think this will work! I will give it a shot and get back to you! I will probably use HashMap with key x_coord_value+"_"+y_coord_value and value the object itself - might be faster than rolling two embedded cycles.
thanks again and regards,
Plamen
Plamen
Hi Plamen,
Yes, a HashMap will probably be faster. We'll be glad to read your solution if you want to share it here.
And don't hesitate to let us know if you still find problems with it.
