the smooth problem of Line
rubby
Post by rubby » Tue Sep 10, 2013 8:11 am
Hello, i find a problem with Line graph.
the code is as follows:
the result is in the attachment "smooth.bmp"
when i remove the line " series.setSmoothed(true);" everything is fine.
the result is in the attachment "no smooth.bmp".
Moreover, if i change
" series.add(100000);
series.add(100000);
series.add(100000);
series.add(100000);
series.add(100000);"
to
series.add(100);
series.add(120);
series.add(350);
series.add(470);
series.add(500);
everything is fine too. Please see the attachment "3.bmp".
So I think there is some problem with the"setSmoothed".
import com.steema.teechart.Dimension;
import com.steema.teechart.editors.ChartEditor;
import com.steema.teechart.styles.Line;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import javax.swing.JDialog;
import javax.swing.JMenuItem;
import javax.swing.JPopupMenu;
 * @author
public class TestTeeChartJunit extends JDialog {
    public TestTeeChartJunit() {
        this.setDefaultCloseOperation(JDialog.DISPOSE_ON_CLOSE);
        setSize(new Dimension(581, 380));
        setTitle("TeeChart for Java - Swing example application");
        tChart2 = new TChart();
        tChart2.setGraphics3D(null);
//        tChart2.addSeries(new Line());
//        tChart2.getSeries(0).fillSampleValues(); //随机数
        Line series = new Line(tChart2.getChart());
        series.add(100000);
        series.add(100000);
        series.add(100000);
        series.add(100000);
        series.add(100000);
        series.getPointer().setVisible(true);
//        tChart2.addSeries(new Bar()); // a bug
//        tChart2.getSeries(0).add(10);
//        tChart2.getSeries(1).add(13);
//        tChart2.getSeries(2).add(49);
//        tChart2.getSeries(3).add(55);
//        Radar   series2 = new com.steema.teechart.styles.Radar(tChart2.getChart());
//       series2.add(50); series2.add(33); series2.add(56); series2.add(88);series2.add(108);
//       series2.setCircled(true);
//       series2.getVertAxis().setAutomaticMinimum(false); //this is ok now.
//       series2.getVertAxis().setMinimum(0);
//        tChart2.setBounds(new Rectangle(0, 0, 500, 500));
        //设置图标的属性
        tChart2.getAspect().setView3D(false); // no 3D
        // tChart2.getLegend().setText("jw legend");
        this.add(tChart2);
        tChart2.setComponentPopupMenu(popup);
        JMenuItem item = new JMenuItem("Property");
        item.addActionListener(new RightListener(tChart2));
        popup.add(item);
        this.setVisible(true);
        TestTeeChartJunit myChart = new TestTeeChartJunit();
    TChart tChart2;
    JPopupMenu popup = new JPopupMenu();
class RightListener implements ActionListener {
    TChart tChart2 = null;
    public RightListener(TChart chart) {
        this.tChart2 = chart;
    public void actionPerformed(ActionEvent e) {
        ChartEditor.editChart(tChart2.getChart());
no smooth.JPG (13.59 KiB) Viewed 12729 times
Re: the smooth problem of Line
Post by Yeray » Tue Sep 10, 2013 2:48 pm
You are right. When you have a Line series with several equal values, the SmoothingFunction (or the Smoothed property) doesn't calculate the values correctly, so I've added it to the wish list to be revised for further releases (TJ71016716).
In the meanwhile, I can only think on checking when this situation happens and disable the Smoothed property.
rubby
Post by rubby » Wed Sep 11, 2013 1:11 am
Hello Yeray,
Thanks for the reply.
where can we can get information of future release? I mean which bugs will fixed.
And what is the probable time?
Thanks!
Post by Yeray » Thu Sep 12, 2013 7:32 am
I'm afraid there's no public roadmap. What you an do is to follow new release announcements through this forum, the RSS news feed or our Twitter and Facebook accounts. And you can check what's implemented on each new release looking at the public release notes.
