Installation trouble
skhms
Post by skhms » Tue Aug 13, 2013 2:55 am
When I attempt to install TeeChart on Redhat Enterprise Linux 5.9
I get these messages and no joy. Can you offer any advice?
java -jar TeeChart.Installer.jar
Exception in thread "AWT-EventQueue-0" java.util.MissingResourceException: Can't find resource for bundle java.util.PropertyResourceBundle, key Activate!
at java.util.ResourceBundle.getObject(ResourceBundle.java:393)
at java.util.ResourceBundle.getObject(ResourceBundle.java:390)
at com.steema.teechart.languages.Language.getString(Unknown Source)
at com.steema.teechart.install.InstallFrame1.jRadioButton1_actionPerformed(Unknown Source)
at com.steema.teechart.install.InstallFrame1_jRadioButton1_actionAdapter.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.JToggleButton$ToggleButtonModel.setPressed(JToggleButton.java:308)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3312)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:682)
at java.awt.EventQueue$3.run(EventQueue.java:680)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:696)
at java.awt.EventQueue$4.run(EventQueue.java:694)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:693)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:97)
Re: Installation trouble
Post by Yeray » Tue Aug 13, 2013 10:18 am
I had to make TeeChart.Installer.jar executable before running it, but it worked for me here in a Linux Mint 15 with your license information and TeeChartJavaSrc_3.2013.0517.zip.
skhms
Post by skhms » Tue Aug 13, 2013 2:16 pm
Thank you for your post. I made the installer executable
chmod a+x TeeChart.Installer.jar
and then reran it
and entered the license information. The "Next>" button in the
"TeeChrt Pro for Java Installation" window remains greyed out.
Toggling the "Choose activation method" generates these messages
in the terminal:
at java.util.ResourceBundle.getObject(ResourceBundle.java:402)
at java.util.ResourceBundle.getObject(ResourceBundle.java:399)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2012)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2335)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:404)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:253)
at java.awt.Component.processMouseEvent(Component.java:6108)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:5873)
at java.awt.Container.processEvent(Container.java:2105)
at java.awt.Component.dispatchEventImpl(Component.java:4469)
at java.awt.Container.dispatchEventImpl(Container.java:2163)
at java.awt.Component.dispatchEvent(Component.java:4295)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4461)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4125)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4055)
at java.awt.Container.dispatchEventImpl(Container.java:2149)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:604)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:275)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:200)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:185)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:177)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:138)
Post by Yeray » Wed Aug 14, 2013 11:03 am
I've just tried the process through the command line, and I haven't needed to set the installer to be executable. This has been enough:
$ unzip -tq TeeChartJavaSrc_3.2013.0517.zip
No errors detected in compressed data of TeeChartJavaSrc_3.2013.0517.zip.
$ unzip TeeChartJavaSrc_3.2013.0517.zip -d TeeChartJavaSrc_3.2013.0517
$ cd TeeChartJavaSrc_3.2013.0517/
$ java -jar TeeChart.Installer.jar
Do you have access to another machine?
If you prefer, I'll send the contents of the jar by mail. This is TeeChart.Swing.jar, TeeChart.SWT.jar and src.zip.
skhms
Post by skhms » Wed Aug 14, 2013 1:24 pm
Unfortunately I have only RHEL machines. If you don't mind,
please do send the files. I am larry.moser at skhms.com.
Do you think I will have trouble using TeeChart on RHEL? Do
I need a particular java version? Mine says
java -version
java version "1.6.0_22"
OpenJDK Runtime Environment (IcedTea6 1.10.4) (rhel-1.24.1.10.4.el5-x86_64)
OpenJDK 64-Bit Server VM (build 20.0-b11, mixed mode)
Larry
Post by Yeray » Wed Aug 14, 2013 2:26 pm
Hello Larry,
I've just sent you a mail with the link to get the mentioned files.
skhms wrote:Do you think I will have trouble using TeeChart on RHEL? Do
java -version
I don't think you should find much problems with it. The tests I made (above) were with Linux Mint 15, that is based on Ubuntu (Debian), but I don't think it will be very different in Red Hat.
If you still find problems with it, please don't hesitate to let us know.
