Internal error
Myti
Internal error
Post by Myti » Tue Jul 30, 2013 10:23 am
This error happens occasionally on a continuously (every minute) updating linear chart.
I'm using TeeChart test version 0722fg.
Have you any idea why it happens?
Thank you!
Ishan.
java.lang.NullPointerException
	at com.steema.teechart.axis.Axis.internalCalcLabelStyle(Axis.java:2042)
	at com.steema.teechart.axis.Axis.calcLabelStyle(Axis.java:3203)
	at com.steema.teechart.axis.Axis.maxLabelsWidth(Axis.java:1484)
	at com.steema.teechart.axis.Axis.internalCalcSize(Axis.java:1539)
	at com.steema.teechart.axis.Axis.getSizeLabels(Axis.java:1577)
	at com.steema.teechart.axis.Axis.calcRect(Axis.java:2459)
	at com.steema.teechart.Chart.axisRect(Chart.java:2197)
	at com.steema.teechart.Chart.calcAxisRect(Chart.java:2216)
	at com.steema.teechart.Chart.internalDraw(Chart.java:722)
	at com.steema.teechart.Chart.paint(Chart.java:2080)
	at com.steema.teechart.TChart.image(TChart.java:1453)
	at com.steema.teechart.Chart.image(Chart.java:291)
	at com.steema.teechart.TChart.getImage(TChart.java:1060)
	at com.steema.teechart.TChart.paint(TChart.java:482)
	at com.steema.teechart.TChart.paintChart(TChart.java:509)
	at com.steema.teechart.TChart.access$400(TChart.java:79)
	at com.steema.teechart.TChart$2.paintControl(TChart.java:341)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:230)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4136)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
	at org.eclipse.swt.widgets.Control.drawWidget(Control.java:1244)
	at org.eclipse.swt.widgets.Widget.drawRect(Widget.java:741)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5473)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
	at org.eclipse.swt.widgets.Display.applicationNextEventMatchingMask(Display.java:4875)
	at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5241)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
	at org.eclipse.swt.internal.cocoa.NSApplication.nextEventMatchingMask(NSApplication.java:94)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3615)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at java.lang.reflect.Method.invoke(Method.java:597)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Internal error
Post by Yeray » Tue Jul 30, 2013 3:20 pm
Hello Ishan,
Myti
Re: Internal error
Post by Myti » Thu Aug 01, 2013 9:01 am
I'm sorry but it's not possible.
We are not even able to reproduce the problem on the developing workstation.
We were trying to understand if the exception is caused by values in the data, values in the labels or something else...
Mauro ( Ishan's colleague )
Myti
Re: Internal error
Post by Myti » Thu Aug 01, 2013 10:39 am
We found the error.
There were some labels in the serie with a null value.
Maybe the next TeeChart can manage this situation without throwing a NPE.
Mauro.
Re: Internal error
Post by Yeray » Thu Aug 01, 2013 10:46 am
Hi Mauro,
How are you adding these null labels to the series?
The following seems to work fine for me here with SWT:
		Bar bar1 = new Bar(tChart1.getChart());
		String s;
		for (int i=0; i<5; i++) {
			if (i!=2)
				s="hi " + String.valueOf(i);
				s=null;
			bar1.add(i, s);
