Vertical title not horizontally center-aligned
znakeeye
Post by znakeeye » Sat Apr 27, 2013 9:25 am
The title is too near the left axis of my bar chart. How can I increase the distance some pixels?
More specifically, I would not consider the above to be center-aligned as the source code suggests. Is it a bug?
znakeeye
Re: Vertical title not horizontally center-aligned
Post by znakeeye » Sat Apr 27, 2013 10:04 am
I changed to the following in Axis.java:
else if ((angle > 0) && (angle <= 90))
    // KD:
    // x -= delta * (n + 1);
    x -= delta * (n + 1) + delta / 4;
    tmpAlign = StringAlignment.CENTER;
Not sure if it's 100% correct, but it works for my chart. Clearly, there is some error at that particular line! :)
Post by Yeray » Tue Apr 30, 2013 2:59 pm
This is how a default chart looks for me.
I just set it to 2D and defined a left axis title:
	private TChart tChart1;
	@Override
	public void onCreate(Bundle savedInstanceState) {
		super.onCreate(savedInstanceState);
		setContentView(R.layout.main);
		LinearLayout group = (LinearLayout) findViewById(R.id.chart_layout1);
		tChart1 = new TChart(this);
		group.addView(tChart1);
		tChart1.getAxes().getLeft().getTitle().setText("Left axis title");
It may be some property you've set that could be relevant to reproduce it. Could you please arrange a simple example project we can run as-is to reproduce the situation here?
