Mark Label is missing when there is a single bar
Jonathan
Post by Jonathan » Tue Jul 24, 2012 4:07 pm
I created a simple pareto chart, and I noticed that mark label is missing when there is a single bar. Is there a fix for this?
Here is run as it is to illustrate the issue above:
		JFrame frame = new JFrame();
		JPanel panel = new JPanel();
		panel.setSize(600, 600);
		TChart chart = new TChart();
		panel.add(chart);
		StringList labelsList;
		// simple one bar
		Bar blueSeries = new Bar(chart.getChart());
		blueSeries.setMultiBar(MultiBars.SIDE);
		blueSeries.add(0, 10, "A", Color.blue);
		labelsList = new StringList(1);
		labelsList.add(0, "10");
		blueSeries.setLabels(labelsList);
		blueSeries.getMarks().setVisible(true);
		blueSeries.setTitle("blue series");
		chart.getAxes().getBottom().getCustomLabels().clear();
		chart.getAxes().getBottom().getCustomLabels().add(0.0, "A");
		chart.getAspect().setView3D(false);
		frame.add(panel);
		frame.setSize(600, 600);
		frame.setVisible(true);
WhebJava
Re: Mark Label is missing when there is a single bar
Post by WhebJava » Wed Jul 25, 2012 3:45 pm
I have the same problem, but I am not using MultiBars.
public NewJFrame() {
try {
initComponents();
setSize(new Dimension(500, 500));
Bar b = new Bar();
b.getMarks().setVisible(true);
t.getChart().addSeries(b);
b.add(1, 1, "a");
jPanel1.add(t,BorderLayout.CENTER);
} catch (Exception ex) {
Logger.getLogger(NewJFrame.class.getName()).log(Level.SEVERE, null, ex);
Post by Yeray » Fri Jul 27, 2012 8:34 am
I'd say I'm getting the expected result here in both cases.
Jonathan's code creates a bar series, adds a point with "A" label, changes the point label to "10" and uses custom labels on the bottom axis to show an "A" on the 0 value:
WhebJava code creates a Bar series and adds a point with "a" label:
Please, explain what result would you expect.
Jonathan
Post by Jonathan » Fri Aug 03, 2012 4:38 pm
I don't see that expected chart in my end. I attached a chart when I ran the sample codes above. As you can see, I don't see the bar label "10".
Missing bar label.png (30.96 KiB) Viewed 31096 times
Post by Yeray » Mon Aug 06, 2012 11:24 am
Hi Jonathan,
Please, attach the complete application so we can import in Eclipse/NetBeans. Or please tell us step-by-step instructions on how to run it in any other environment.
Jonathan
Post by Jonathan » Mon Aug 06, 2012 3:07 pm
Since the max. allowed size is 512 KB, I had to remove the lib file and I attached the exported eclipse zip file. BTW, What version of Teechart lib are you using? I am using Teechart version 2. (I also tried with TeeChartJavaSuite_2012Eval.zip)
TeeChart_MissingLabels_Jonathan.zip
(3.2 KiB) Downloaded 1903 times
Post by Yeray » Wed Aug 08, 2012 12:01 pm
Hi Jonathan,
Thanks to your application I could reproduce it. It seems it only happens in the swing version.
I've added it to the defect list to be revised asap.
WhebJava
Post by WhebJava » Wed May 29, 2013 8:59 pm
Do you have a date to release this fix?
Post by Yeray » Thu May 30, 2013 2:44 pm
I'm afraid this hasn't been fixed yet (TJ71016294).
I'd suggest you to follow the following channels for new release announcements: this forum, RSS news feed, Twitter and Facebook
And check what's implemented on each new release looking at the public release notes:
https://www.steema.com/versioninfo/java
