Problem with an area
micha
Post by micha » Mon Jul 23, 2012 2:57 pm
Hi i have a Problem with an area.
Here is my first area... this area has axis breaks
but when i switch the area to another area without axis Breaks, it seems that there is a little Problem.
first i remove all series on the Tchart and then i generate a new area.
But:
What can i do? Repaint? Update?
Re: Problem with an area
Post by Yeray » Thu Jul 26, 2012 3:02 pm
Hi micha,
It would be helpful if you could arrange a simple example project we can run as-is to reproduce the exact situation and the problem you are getting.
