TeeChart Delphi and TeeChart Java
Wheb
Post by Wheb » Wed Dec 23, 2009 7:43 pm
In Delphi I insert the values:
Query:= TQuery.Create(Self);
 Query.Tag                     := 1000;
 Query.DatabaseName            := Protocolo_Receita_q.DatabaseName;
  Query.SQL.Add(' select trunc(dt_exame) dt_exame, ' +
                          '        sum(vl_exame) vl_exame    ' +
                          ' from   med_result_exame          ' +
                          ' where  nr_seq_exame   = ' + Med_Resultado_Exame_q.FieldByName('nr_seq_exame').AsString +
                          '   and  nr_seq_cliente = ' + nr_seq_cliente_ed.Text +
                          '   and  nvl(ie_valido,'+QuotedStr('S')+') <> ' + QuotedStr('N') +
                          ' group by trunc(dt_exame) ' +
                          ' order by 1 ');
 TDBChart(Grafico).Series[i].Title                 := Med_Resultado_Exame_q.FieldByName('exame').AsString;
 TDBChart(Grafico).Series[i].Marks.Style           := smsValue;
  TDBChart(Grafico).Series[i].Marks.Visible         := True;
  TDBChart(Grafico).Series[i].XLabelsSource         := 'DT_EXAME';
  TDBChart(Grafico).Series[i].YValues.ValueSource   := 'VL_EXAME';
  TDBChart(Grafico).Series[i].DataSource            := Query;
  TDBChart(Grafico).Series[i].Active                := True;
  TDBChart(Grafico).Series[i].ShowInLegend          := True;
  TDBChart(Grafico).Legend.TextStyle                := ltsPlain;
  TDBChart(Grafico).LeftAxis.Inverted               := False;
And TeeChart show :
In Java I insert the values:
for(WChartSerieValorVO valores : serie.getValores()){
DateTime dt1 = valores.getVlEixoX() != null ? new DateTime(((Timestamp)valores.getVlEixoX()).getTime()) : null;
Double db = valores.getVlEixoY() != null ? ((Number)valores.getVlEixoY()).doubleValue() : null;
s.add(dt1, db);
And TeeChart show :
The values in Delphi and Java are the same, but the design does not. I need the design in Java is the same in Delphi. How do I do?
Re: TeeChart Delphi and TeeChart Java
Post by Narcís » Thu Dec 24, 2009 8:35 am
Hi Wheb,
Are you using the same settings for Java as you do in Delphi? Could you please attach simple example projects or code snippets we can run "as-is" to reproduce the problem here?
Wheb
Post by Wheb » Thu Dec 24, 2009 12:06 pm
Sorry, I saw that I forgot to put the code line
TDBChart(Grafico).Series[i].XValues.ValueSource   := 'DT_EXAME';
in Delphi, so the results were different.
Tanks;
