Date-Time not showing in correct format after export excel
essar
Post by essar » Tue Jun 16, 2009 7:08 am
Chart in my application has Date-Time data on X axis. when i am exporting data to excel format, X-col data is not showing in proper date-time format. This application has been made in Asp
eg:
X axis value shown in chart : 16/6/2009 11:29:01 AM
After export to excel : 39980.47848
Kindly provide me solution to resolve this issue.
Re: Date-Time not showing in correct format after export excel
Post by Yeray » Tue Jun 16, 2009 9:22 am
Hi essar,
Here you have an answer to a customer who asked the same in the past.
essar
Post by essar » Thu Jun 25, 2009 11:15 am
Thanks for reply. I need to show heat-no on x axis. As heat no. is in varchar format for eg "D12345". My chart is not able to show this type of data on x axis.This data is being taken out by database. When i am trying to show any data other than of numerical or datetime, its showing me error that data is not in double format. I know i might be going wrong somewhere but still i need your help. do these type data can be shown on x axis. Kindly reply and thanks for all your prompt replies.
Post by Yeray » Thu Jun 25, 2009 12:04 pm
Hi essar,
TeeChart needs doubles or integers (datetimes are also doubles) as X values to display the charts. If you don't want to set an irregular X interval, you can let TeeChart to add the values in X integer sequence (0, 1, 2, 3,...) without specifying any X. Then, if you have your values with a label (for example D12345), you could set your bottom axis to display your series labels instead of the X values:
Chart1.Axes.Bottom.LabelStyle := talText;
If you need more precise help, please, try to arrange a simple example project we can run as-is here to reproduce the issue here and we'll try to give you some tips.
essar
Post by essar » Fri Jun 26, 2009 7:00 am
Dear yeray,
Code given by you worked to some extent. I got fixed value on x axis but the value i got was like (1,2,3,4,...)...as you said in you previous reply. But i need the Heat no. values on x axis instead of these integer values. and heat no are also not fixed, it depends on user selection from the interface. Heat no. is also take from database. The sample of my code is some what like this:
mQuery = "select heat_no,avg_cast_speed ,L2Speed from heat_report where heat_start_time >= to_date('06/06/2009 00:00:00','mm/dd/yyyy hh24:mi:ss') and heat_start_time <= to_date('06/06/2009 23:59:59','mm/dd/yyyy hh24:mi:ss') and caster_no=1"
                    mRSAim.CursorLocation = 3    //adUseClient
                                mRSAim.Open mQuery,mDBC,adOpenStatic
                document.graph.Chart1.ClearChart
                document.graph.Chart1.style.visibility = "visible"
                document.graph.Chart1.Environment.IEPrintWithPage=true
                document.graph.Chart1.Aspect.View3D = false
                for i=0 to mRSAim.fields.count -2
                                document.graph.Chart1.Axis.left.Automatic = true
                                document.graph.Chart1.AddSeries(scBubble)
                                document.graph.Chart1.Series(i).DataSource = mRSAim
                                document.graph.Chart1.Series(i).YValues.ValueSource = mRSAim.fields(i+1).name
                                //document.graph.Chart1.Series(i).XValues.ValueSource = mRSAim.fields(0).name
                                document.graph.Chart1.Series(i).Title = mRSAim.fields(i+1).name
                                document.graph.Chart1.Axis.Bottom.Labels.Style = talValue
                next
Here i have commented x axis values, that i was taking prior to your reply and added the last line as u suggested. Kindly help me to rectify this code and achieve the desired results.
Post by Yeray » Fri Jun 26, 2009 8:04 am
Hi essar,
I'm not sure of what you should do because I still don't understand what are you trying to retrieve from your database. What data type is heat_no? Is that what you want as X values? Or you want a continuous X (like the integers 1, 2, 3,...) but showing heat_no string?
See this example:
If you have X values or dates in the field 0:
document.graph.Chart1.Series(0).XValues.ValueSource = mRSAim.fields(0).name
If you don't get any X from database, the continuous integers will be used.
If you have Y values in the field 1:
document.graph.Chart1.Series(0).YValues.ValueSource = mRSAim.fields(1).name
If you have labels in the field 2:
document.graph.Chart1.Series(0).LabelsSource = mRSAim.fields(2).name
document.graph.Chart1.Axis.Bottom.Labels.Style = talText
If you don't get any labels from database nor set bottom axis labels style to show labels, the X values will be shown.
essar
Post by essar » Fri Jun 26, 2009 8:25 am
Thanks Yeray,
Your last code gave me the exact answer i was searching for. I am highly impressed by your promptness. Thanks..
Post by Yeray » Fri Jun 26, 2009 8:50 am
Hi essar,
You are very welcome!
I'm glad to see that you solved it!
