Break in the line for FastLine chart
KingDesigns
Post by KingDesigns » Wed Mar 18, 2009 5:33 pm
In some cases the data that I am working with on a FastLine chart will have NULL values for the limits in the database. I would like to have a break in the line when those values are NULL rather than a line drawing from the last non-null value to the next non-null value. Is there a setting that I can use to force that to happen?
Post by Yeray » Thu Mar 19, 2009 8:28 am
Hi KingDesigns,
I think that you are looking for this:
  TChart1.Series(0).asFastLine.IgnoreNulls = False
  TChart1.Series(0).asFastLine.TreatNulls = tnDontPaint
Otherwise, please, take a look at the demo at What's new ?/New in Series/Fast Line TreatNulls
KingDesigns
Post by KingDesigns » Thu Mar 19, 2009 12:49 pm
I am thinking that those properties are in the newer version. I am using version 7 and they are not available. Is there a way do this for v7?
Post by Yeray » Fri Mar 20, 2009 8:13 am
Hi KingDesigns,
In v7 the property TreatNulls doesn't exist, but you can set IgnoreNulls as false and they shouldn't be displayed. As a simple example, this works fine for me with TeeChart ActiveX v7.0.1.4.
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scFastLine
  TChart1.Series(0).FillSampleValues 25
  TChart1.Series(0).SetNull 5
